Here's my cam specs. I'm wondering If I can advance this cam 4* to try and pick up some low end. Right now I'm only getting 140psi cranking compression. I had heard that with an intake lobe centerline of 107, and an LDA of 112, that meant there was allready 5deg. of advance ground into this cam. I know that's the right math for a single pattern cam, but not sure if it applies to a dual pattern. Can anybody help me out. It's a Summit cam if that helps.
The only way to know where to set the cam timing is to use a degree wheel. That way you know if the gears and chain are where they are suppose to be even if something was messed up during production.
The only way to know if changing the phasing of the cam gained anything requires testing output before and after the change. There is a lot more to it than cranking pressure. I wouldn't use that as your only measure. The cam you have is pretty mild. Unless you have under 8:1 compression, that should perform good. If you want more torque, go with a wider LDA.
