1980 Accessory Pulley questions
Old 11-12-2007, 12:37 PM
Ak. Mal
Ak. Mal's Avatar
Location: Kansas City, MO ...I'd like to go fishing and catch a fishstick. That'd be convenient. - Mitch Hedberg
Default 1980 Accessory Pulley questions
How many grooves should there be on the water pump and crank pulleys? My AIM says three each. My car has a 2 groove on the water pump currently, but it's out of round and needs replaced. This winter I'm putting the Smog pump on my car and think I need the third groove on the water pump to make it all work. I can't find anyone that even sells a 3 groove short water pump pulley.
The AIM also shows the that the most forward groove on the crank pulley should be smaller and connected to the P/S pump. Is that correct, because that's not what is on my car. From memory, all three grooves are the same diameter.
Can anyone provide me with any pictures of the correct pulley set up with the smog and A/C connected.
Thanks.
Old 11-13-2007, 09:25 AM
Ak. Mal
Ak. Mal's Avatar
Anyone?
Old 11-13-2007, 12:09 PM
8T8T2
8T8T2's Avatar
I have a 80 and will check. A couple of yrs. ago I installed Spal electric fans and done away with the air pump. If memory serves me right its only a 2 belt pulley with seperate single pulley bolt on addition to make it 3. At work right now so it won't be till late this evening till I can check.
Old 11-13-2007, 01:36 PM
Crash80
Crash80's Avatar
I am gonna say it is three (crank) and three (water pump) but my memory could be foggy.
Old 11-13-2007, 03:56 PM
TPI BOY
TPI BOY's Avatar
Old 11-13-2007, 04:59 PM
Ak. Mal
Ak. Mal's Avatar
Does the second pulley slip over the center of the 2 groove pulley to create the third row? Is the third row pressed up next to the now middle row?
I'm so confused by this because I can't seem to find anything to document it.
Old 11-13-2007, 05:17 PM
...Roger...
...Roger...'s Avatar
Both crank and water pump 3rd grooves are add ons.The one on the crank for the PS is smaller.
http://www.corvette-paragon.com/cata...4-5BE6E37FC45B
http://www.corvette-paragon.com/cata...7-482B0184FAC1
Old 11-14-2007, 04:45 PM
Ak. Mal
Ak. Mal's Avatar
Thanks for clearing this up. I now know that I have more problems than and out of round pulley. I also have the wrong size. Mine is a 7 1/8" OD pulley based on the part number. I should have a 6 1/4" OD pulley stock. So, would this explain why my alternator seems to be on the high side of the voltage range?
To 1980 Accessory Pulley questions
Quick Reply: 1980 Accessory Pulley questions
