My vette has cruise control with a resume feature. There is a 3 wire electrical connector that plugs into two electrical spades on the transducer. My question is will a transducer made for a 2 wire electrical connector work on my car? Thanks
I will 3rd that and I'm pretty sure you can transfer the resume solenoid to your new 2 wire transducer.
edit -should note the 2 mounting bosses will be missing but the bracket will still be held by one of the mounting bolts.Not sure if the solenoid has its own ground or needs the bracket.
If you have a tranducer with 3 spades coming out of the tranducer all together at one spot then the 3rd spade is not used on the vette-its for a cruise light that was used on other cars.2 wire will work like the 3 you just wont use the 3rd
