67 burning out voltage regulators !!
Old Nov 13, 2007 | 08:53 AM
pmihaltian's Avatar
pmihaltian
Slingshot
Default 67 burning out voltage regulators !!
My 67 327 300 HP has started eating voltage regulators. I am on my third one from Ecklers. I seem to be overloading the unit somehow and burning them out. I think it might be my power window switches pulling too much of a load, but I'm not sure. Any ideas will be greatly appreciated.
Old Nov 13, 2007 | 08:58 AM
Garys 68's Avatar
Garys 68
A bad diode wil kill regulators. Did you have the alternator checked?
Old Nov 13, 2007 | 09:53 AM
...Roger...'s Avatar
...Roger...
Make certain you are getting a "solid" ground to the alt.and voltage reg.
Old Nov 13, 2007 | 01:30 PM
markdtn's Avatar
markdtn
If you don't care about originality, you can pretty easily adapt a solid state VR from a '70s Ford.
Old Nov 13, 2007 | 08:47 PM
hugie82's Avatar
hugie82
I had to bend (open it up .010)the contacts on the secondary coil so it wouldn't make contact when the primary was being used. It stopped mine from burning up again.
Old Nov 17, 2007 | 01:18 AM
pmihaltian's Avatar
pmihaltian
Slingshot
Thanks, guys, this is great stuff! I'll definitely check it out. Wouldn't surprise me a bit if it's a bad batch of voltage regulators! But the ground wiring is definately a lead. Than ks again.
Old Nov 21, 2007 | 12:04 AM
pmihaltian's Avatar
pmihaltian
Slingshot
Default I still have the same problem
I have tested the regulator at Auto Zone and it check out ok. I did find a freyed ground wire leading to the regulator. I have since repaired that wire and several others. However, I still have the same problem, generator light is on and won't turn off, and ammeter shows a discharge.
I plan to have the alternator tested, I figure that's the next logical step.
Any other ideas?
Old Nov 21, 2007 | 07:33 AM
...Roger...
Because you said you are on the 3rd voltage regulator I think you have a problem with wiring or grounds.(make sure the alt. belt is not slipping)In your case I would run temporary extra grounds from battery neg. terminal to the alt. case and the voltage reg. case.
Next you can bypass the voltage reg. and put your alt. into full output.With the engine running remove the small 2 wire connector on the alt..One of the terminals in the alt. should be marked with an F.Take a jumper and connect the F terminal to the large pos. term. on the back of alternator.If you hear the alternator whine its probably working.Check your amp. meter or check the voltage at the back of alternator.If this makes your alt. work then your reg. is not working-could be reg. or wiring.Let us know what happens.
Old Nov 26, 2007 | 09:19 AM
pmihaltian's Avatar
pmihaltian
Slingshot
Default Problem solved !
Thanks so much for all of your help with my electrical problems, the solution wouldn't have been possible without the Forum members!
After replacing the alternator and voltage regulator (yet again), and then having the problem where the car wouldn't shut off even after the key was turned off, I decided to take the Corvette Forum's suggestion of replacing the old-style voltage regulator with the Wells VR-715 electronic, solid-state version. Not only did it solve the problem of the constant discharge or the car not turning off, but the car starts easier and quicker than it ever did in 18 years of ownership!!! I will never use an old-style of voltage regulator again, that's for sure.
I can't tell you how thrilled I am. Thank you so much for ending this 6 weeks of frustration, and finding the solution for me.
To 67 burning out voltage regulators !!
