Jackson: What kind of lobe separation will this cam give me. $89 seems like this would be low quality?? I'm thinking 110 degrees as I seem to remember this.
Checked out the speed pro book and it says with a 76 cc heads and
.025 piston to deck will net 9.35:1 Should I try to get 10:1 for the most HP for this "stock casting combo". Should the cam have a small amount of "lope" for the most seat of the pants feel.
Sorry for all the ?'s as it has been 25 years since I have been wrenching on small block chevy's.
Whats wrong with a flat top piston 64cc 291 head, I can see using a domed
piston if your just stuck with using a 76cc head, if you have a 64 cc head use
it with a flat top piston.
Could use either one except the 291's don't have holes (not that big of a deal) but the 993's keep the numbers matching. If you guys thought the 291's would give me enough of an HP advantage over the number match combo I would consider it!
okay...so i already have that cam in my engine. what if i would install those pistons AND the vortec heads? right now i have original '77 l-48 heads on a 290 hp crate shortblock. what kind of gains are possible with this combo?
Do NOT run H618CP (+3.5cc dv) & Vortecs (64cc) together ... too much compression (~11:1 or more) ... also, maybe not sufficient clearance within vortec chamber for dome.
You have 1105 cam ? Not 1103 ... but you have 1105?
IMHO, 1105 cam is too much for 350" w/ dished pistons & ~76cc chambers.
I thought you're trying to save $ re: 'wife/$ police' ... and ... I thought you're trying to maintain matching #'s too. Maybe I'm mistaken on both counts.
Summit's house brand cam&lifters are good quality ... it's what discount marketers call a loss leader ... they gamble you'll add other hi-profit pieces to an initial order item that's a true bargain. Dig deeper; Summit specifies 109 icl & 114 lsa for K1105. BTW ... just a coupla months ago they were $70. About same % increase as today's propane delivery.
Dig deeper into SP catalog too ... it tells you ... catalog's sbc cr quotes are based on stock deck & 0.038" gasket & are accurate for that combo ... my higher scr quote based on thinner gasket w/ improved quench ... my combo's quote is accurate too.
flattops/dish & 64cc are fine ... & so are domes & 76cc ... your car/choice.
If I were starting from scratch / money no object / numbers match no object ... I'd prefer flattops/dish & 64cc. My suggestions based on how I interpreted your posts.
I doubt you could tell any difference in performance. burn across a flat
surface is a little better. but if the 291s don't have the holes in the
end for accesories and numbers matching is good on a 72, anything
that has steel bumbers is worth money. I have been watching the
forum for awhile and quite a few have used the summit cam and lifters
have not seen anyone come on the forum complaining of a falure.
I don't have any books on casting numbers, I did look at the Z/28 site
for casting numbers it showed a 993 casting going up till 1976 for a 350 with a valve size of 172/150, I find it hard to believe chevy used a 1.72
intake valve on a 350 but if thats the case use the 1.94/1.50, 291.
Your right Jackson I am worried about the money police but I don't want to do something dumb so bear with me. I have not bought small block chevy parts in 20 years. The last time I bought parts was from JC Whitney and back in the day the only heads to get some HP were the 461's. I want my cake and I want to eat it to!! (but I know thats no going to happen)
Thanks again for the help.
1105 Probably AOK with vortec & most flattop or dish ... but Depends on piston, gasket & deck clearance ... exactly what do YOU have?
all i know is that it's a gm crate 350 290hp with 1977 casting heads (l-48). i would suspect it has flap top pistons. never dug that deep into it lol. but the 1005 cam works fine now...i can tell the low end torque could be greater, but i think the vortec heads will help that.
complete 290HP crate GMPP P/N 12499529 comes with DISH pistons. If you have 1105 cam ... vortecs will definately wake it up.
funny, I was thinking about base engine 72 today and how it is a dog. It was rebuilt about 10,000 miles ago and it is stock except for the Comp 268H cam. It is not the right cam for this. The car has air and ps pb. I was thinking about adding a set of votec heads and a votec manifold with headers and keeping the cam. I would like more snap-just a good running car with some snap. The way it is now it is just plain doggy.
I had thought about a crate motor--if so any recommendations.
Base '72 sbc (L48) came w/ dish pistons & heads about 76cc. If yours was rebuilt w/ dish pistons ... then vortecs or other heads w/ about 64cc chambers would make a big performance difference. If motor's just 10K miles ... I'd put some heads w/ 58cc to 68cc chambers on it.
It was rebuilt with dish pistons. What would the compression be with the 64cc heads. I was going to order from Chev, but if I can find some used which ones and part number? I wonder if I put the votec heads on it and the votech intake with a 600 demon or holly would it all fit under the stock hood?
SCR probably will range about 9.5 - 9.7:1. depends on bore ... specific piston dome volume ... compression height ... and gasket.
If you have base 72 you have very low hood ... lowest vortec intake w/ drop base air cleaner assembly should fit ok.
jackson, thank you for all your information and knowledge. if it is okay i am going to keep you in mind, then i can contact you if i ever have any questions.
thanks again!
Jakson; I have decided to go with the combo you have suggested . I plan to clean up the castings inside the valve pockets to promote flow. (not sure if this will help the 993's)
Jackson, Thanks for your help. I was looking at the Eldebrock intakes website they spell out that a vortec intake will not fit or clear a corvette hood. I really would like to do this, but do not want to change hoods or have clearance problems. I am ordering a set of heads from chevy on Friday and getting the intake coming as well., but I want to make sure do not run into clearance issues. I am sure someone has a 68-72 vette so equiped.
Also, are these heads the centerbolt? I think chevy makes adapters to run the old style valve covers which I would like to do as I have had these on the car since 1974.
Yes vortecs are centerbolt. Adapter kit GM P/N 24502540.
