75 finally ready for Paint!
Old Nov 19, 2001 | 09:05 PM
Paul 75 L82's Avatar
Paul 75 L82
Default 75 finally ready for Paint!
Here's some pic's!
Old Nov 19, 2001 | 09:26 PM
PatsLs1vette's Avatar
PatsLs1vette
Default Re: 75 finally ready for Paint! (Paul 75 L82)
looking good so far when you painting it?
Old Nov 19, 2001 | 09:29 PM
Chris Fowler's Avatar
Chris Fowler
Cruise-In IV Veteran
St. Jude Donor '03-'10
Sweet!
Just a quick question, though...
Why a different primer on the body than the rear bumper? Is it also different on the front bumper? Is it a fiberglass thing?
Old Nov 19, 2001 | 09:42 PM
Paul 75 L82
Default Re: 75 finally ready for Paint! (Chris Fowler '80)
Going for paint on Friday. The bumpers just have the DP50 on them, where the body has the K36 surfacer on top of the DP50.
Old Nov 19, 2001 | 09:45 PM
QuickVet's Avatar
QuickVet
how long did it take to prepare for paint?
Old Nov 19, 2001 | 09:51 PM
Paul 75 L82
Default Re: 75 finally ready for Paint! (Vetteboy)
117 hours to strip and sand, 34 hours to seal, prime and block sand. Working on weekends and a couple of vac days from work, all in all it took 3 months.
Old Nov 19, 2001 | 09:55 PM
QuickVet's Avatar
QuickVet
:eek: wow! what did you use to strip and sand the car?
Old Nov 19, 2001 | 10:00 PM
Paul 75 L82
I used Klean-Strip for Fiberglass to strip, very messy job. Used a 16" & 11" sanding boards. They are 2 1/4" wide and used 80 grit 3M Gold sand paper thats on a roll, sticky on the back side to stick to the boards. Then 150 grit before sealer.
Old Nov 20, 2001 | 12:54 AM
slide's Avatar
slide
Looking good. I just sprayed my 75 a couple weeks ago and there's one thing you want to make sure of before you spray your color, if you have your interior in the car make sure that the two luggage rack holes next to the rear window are taped off from inside the car. If you don't you'll have a lot of over spray to clean off your interior. One other thing, are you aware that you'll have to scuff the primer sealer before you spray the color coat ? Sealer needs to be scuffed if it sits longer than 8 hrs. Just a couple tips. :D Look forward to seeing completion pics.
Old Nov 20, 2001 | 06:46 AM
Larry B.'s Avatar
Larry B.
My 69 looks just like that. I will be painting Friday as well . Looks like a perfect day here for painting. 78deg. low humidity. Good luck on you paint job. I don't know if you have access to a spray booth but I noticed in your picture it is in a home garage. I have done several cars that way with excellent results. Here is a couple of tips to reduce dirt. Make SURE you have MORE filtered inlet area than exhaust fan area so you will not create a vacuum and pull dust and dirt from all of the cracks and crevices(that's where most the dirt is).By doing this you will have a nice flow of air through the shop. Also ground the car and spray gun to avoid static charge.
[Modified by silvervetteman, 3:09 PM 11/20/2001]
Old Nov 20, 2001 | 08:48 AM
Paul 75 L82
Default Re: 75 finally ready for Paint! (silvervetteman)
I'm not going to paint the vette myself. I thought about it for a long time. I feel I could do OK. I got where I could lay down the K36 very smooth. You sand everything so much you can always fix minor problems. But I will give way to the experts. I have ordered everything new that goes on the outside of the car, handles, badges, and etc. It ought to look great soon.
Old Nov 20, 2001 | 09:26 AM
1LE's Avatar
1LE
Are you going back to the original Dark Red color?
Old Nov 20, 2001 | 09:32 AM
TR69's Avatar
TR69
I too just am about ready for paint. I just have to sand the K36 for the last time (I hope) and like you I
am going to let someone else paint it. Good luck.
Old Nov 20, 2001 | 11:49 AM
Paul 75 L82
Default Re: 75 finally ready for Paint! (1LE)
1LE, I am going to stay with Dark Red, it's the safest bet for the long run.
TR69, the last sanding when fast. I cross-hatched 220 and got everything real smooth. It's alot faster that the other times I sanded.
Old Nov 20, 2001 | 12:09 PM
Chris@VetteFinders's Avatar
Chris@VetteFinders
Platinum Supporting Dealership
Looks like you did a great job. I doubt I could have done that myself. I am not good at detail work.
To 75 finally ready for Paint!
