Best gear for .82 OD
Old Nov 15, 2007 | 09:44 AM
Bangkok Dean's Avatar
Bangkok Dean
Default Best gear for .82 OD
What is the best rear gears for a 5 speed OD .82 for cruising at 85mph?
Old Nov 15, 2007 | 10:17 AM
Durango_Boy's Avatar
Durango_Boy
Using 3.55s will give you a good cruising speed and leave a little bit down low for 1st gear fun.
Old Nov 15, 2007 | 10:22 AM
Glensgages's Avatar
Glensgages
..... 'assuming' a 27"-tall tire is used, 85 MPH with .82:1 OD ratio is:
2.72 - 2340 RPM
2.87 - 2470
3.08 - 2650
3.31 - 2850
3.55 - 3050
3.73 - 3200
3.90 - 3350
4.10 - 3535
Formula is: MPH x GR (Gear Ratio ) div/by .006 div/by 1/2 TH (Tire Height ) x OD-ratio
85 x 2.72 div/by .006 div/by 13.5 x .82 = 2340 RPM (see-above )
Old Nov 15, 2007 | 10:32 AM
GTR1999's Avatar
GTR1999
Most of the diff I set up for guys with OD were 373's. All based on thier own choice. Some 355's but just about all 373.
Old Nov 15, 2007 | 10:51 AM
gkull's Avatar
gkull
On my list of things to do is change my 5th gear OD ratio from .64 to .82
I presently have 4.11 rear X .64 = 2.6304 effective ratio. I have enough TQ to pull and even higher gear so my plan is to 3.08 X .82 = 2.5256
I'm always doing way too many RPM driving the local freeways. I glance down at the tach and I'm often way over 4000 rpm cruising.
Old Nov 15, 2007 | 11:31 AM
bashcraft's Avatar
bashcraft
How often do you cuise at over 120 mph?
Old Nov 15, 2007 | 12:02 PM
gkull's Avatar
gkull
I forgot to add that i have a fear of being rearended!
This picture was taken after I slowed down to about 4200 rpm. I just didn't feel safe fumbling with a camera when my speedo needle was straight down off past 140 mph. It was curvy road through a canyon following a small river
I also have some on track videos doing a 4-5 shift at near 140 mph and track radar gun had me at 156 mph just before the braking zone.
Years ago at Bonneville Salt Flats I was able to do 7000 rpm with 28 inch 300 mph tires using a .70 OD and 4.11 rear.
Old Nov 16, 2007 | 01:19 AM
Bangkok Dean
I guess I can put my 3.73 gears back in now that I have the 5 speed, thanks for the info folks.
Old Nov 16, 2007 | 03:00 AM
OzzyTom's Avatar
OzzyTom
gkull, if you have the 0.64 OD ratio, I'm assuming you have a TKO-600.
Why do you want to change the OD ratio?
It is much better for keeping rpm down at highway speeds in your situation.
Give it some more thought: I'd be sticking with the 0.64 ratio OD, but change the diff to ~ 3.9 or even 3.73.
That way you still keep a good 1st gear ratio for take offs, and 4th gear will carry you over the qtr mile at around the right rpm for best utilisation of power, and 5th is your high speed cruising gear.
I have a 3.36:1 diff, and the 2.87 1st gear is about as tall as I would want (overall 9.64) A 3.08 diff ratio will make your overall 1st gear lug a bit on takeoff..... you'll be riding that clutch a bit in traffic (if it is used as a driver)
but then if your spending time at the salt flats..... go for the 3.08 with the .64, and add a bit of N2O.... that'll wind the needle off the clock
Old Nov 16, 2007 | 05:23 AM
murraybs's Avatar
murraybs
Holy crap, where'd you do that?
The only place I feel really safe opening it up is on I-5 between Buttonwillow and Stockton.
Old Nov 16, 2007 | 09:21 AM
Belgian1979vette's Avatar
Belgian1979vette
And I thought that in the USA behind every tree there was a cop hiding with a radar gun...
Anyway would like to go with OD someday, but don't like to put down 3500 $ to do so.
Old Nov 16, 2007 | 09:27 AM
Durango_Boy
You can do a Ford T5 retrofit for about $1200 depending on your parts finding skills. You can pick up a low mile T5 for $500 to $700. The T5 is a great five speed manual to look at when you're on a budget.
If you like automatics, then a TH200R4 is very easy to find for about the same price as above. Drop a few hundred into a rebuild that you perform yourself, and you can have OD either way, for under $1500.
Old Nov 16, 2007 | 10:47 AM
gkull's Avatar
gkull
The jump from 1.00 to .64 is way to much.
I am much more interested in making first and second gear more usable.
Old Nov 16, 2007 | 04:58 PM
OzzyTom's Avatar
OzzyTom
I agree, the gap IS too wide from 1.00 to 0.64 to make it useful for anything other than highway cruise.
Old Nov 17, 2007 | 06:58 PM
brngrhd's Avatar
brngrhd
i'm going with with 3.25 rear ratio for my tko 2 but it has a 3.27 first so it will work well, all around i think.
Old Nov 25, 2007 | 09:55 AM
OzzyTom's Avatar
OzzyTom
First opportunity to run my vette on a longer cruise today with the new motor and gearbox.
I have the 0.82 OD ratio with a 3.36:1 diff.
I am happy with my choice.
I sat on 65~70 mph and car drops 500 rpm from 4th to 5th.
Noise level is markedly lower at 2400rpm compared to 2900 rpm, and motor (383) still pulls strong in 5th up hills....
It is a very usable 5th gear.
cheers
tom
Old Nov 25, 2007 | 11:39 AM
brngrhd's Avatar
brngrhd
cheers
tom
great that means i should be very happy with my 3.25 ratio on my big block.
To Best gear for .82 OD
Old Nov 26, 2007 | 07:55 AM
OzzyTom's Avatar
OzzyTom
3.25 ratio ??? where?? at the diff??? unusual ratio for a 69 vette.
How did you determine that ratio?
standard ratios in chrome bumper vettes that I am aware of were....
3.08, 3.36, 3.55, 3.73 and 4.11
In any case..... a big block should pull tall gearing without issues.
Old Nov 27, 2007 | 12:07 AM
brngrhd's Avatar
brngrhd
strange nine inch
Old Dec 3, 2007 | 12:44 AM
OzzyTom's Avatar
OzzyTom
strange nine inch
That is strange...
