Intakes
Old Nov 15, 2007 | 07:25 PM
derv3tt3's Avatar
derv3tt3
Default Intakes
Right now I'm running a Weiand 8000 witch according to Weiand is the same as their 8004.Summit has a stage 1 good idle to 6000rpm.Any better than what I already have? What do you suggest?
My engine is a mild 383 Edlebrock RPM heads,extreme energy 268 cam and a Jet Stage 2 Q-Jet carb.
Old Nov 15, 2007 | 10:46 PM
Durango_Boy's Avatar
Durango_Boy
Keep it. You have a good manifold.
Old Nov 16, 2007 | 02:56 PM
KJL's Avatar
KJL
I was running am RPM air gap on my 427 small block. I decided to try a Super Victor single plane, race ported etc. I put it on the dyno and lost quite a bit of low end torque with little gain in top end. My idle kind of sucked as well. I switched back to the dual plane and got my low end back. I have done a LOT of reading and research regarding intakes and have come to the conclusion that for street applications the Edelbrock RPM air gap gives the best of both worlds. I am also using a 2" 4 hole contoured spacer. I also gasket matched/ported to my heads.
Old Nov 16, 2007 | 03:14 PM
derv3tt3's Avatar
derv3tt3
Default intakes
Sounds like you have a raised hood.
Old Nov 16, 2007 | 03:21 PM
KJL's Avatar
KJL
Just a tad
Old Nov 16, 2007 | 03:32 PM
derv3tt3's Avatar
derv3tt3
Just checked your pictures.
Old Nov 16, 2007 | 03:37 PM
rayluka's Avatar
rayluka
Not just raised............. thats elevated
To Intakes
