Alum. Rivets, Seat Support
Old Nov 16, 2007 | 07:24 AM
GEORGE TAYLOR's Avatar
GEORGE TAYLOR
Default Alum. Rivets, Seat Support
Any One Know A Way To Install These With Out The Tool?
I Only Have To Do A Few.
Old Nov 16, 2007 | 08:53 AM
Edzred72's Avatar
Edzred72
If your taliking about the metal supports under the car that the front seat tracks bolt to....that's all you need is a helper holding a bucking bar. Helper holds a heavy 5lb or more flat faced hammer against the rivit face while you whack the other side. Start tapping slowly to get a nice straight mushroom...then peen away shaping as you go. Got mine to look "almost" factory.
Eddie
Old Nov 16, 2007 | 12:04 PM
AzMotorhead's Avatar
AzMotorhead
Limping across the line
If I knew where you lived I could come over and use my rivet gun
To Alum. Rivets, Seat Support
