Anyone install a fuel injection system?
Old Nov 22, 2007 | 06:01 AM
mrvette's Avatar
mrvette
MY L98 setup was installed in '95 or so, works great, but watch the wiring issues, or get an aftermarket harness, the grounds are critical, the thing will run, but not well with out using individual wires for each computer ground, to the engine block...
Old Nov 22, 2007 | 08:58 AM
shafrs3's Avatar
shafrs3
Originally Posted by I'm Batman
This is a subject with a lot of archives coverage.
FI, EFI or "fuel injection" should work well as search terms. http://forums.corvetteforum.com/show....php?t=1603168
There's a guy here that pointed out that the current search feature won't work correctly with queries below 4 letters.
Old Nov 22, 2007 | 09:18 PM
Z-man's Avatar
Z-man
Yep - if you want to search for only "EFI" you just put it in twice so you get more than 3 letters - EFI EFI
I've got a Holley C950. It starts in a second or two no matter how long the car sits or what the temperature is - I'll never go back to a carb.
Old Nov 22, 2007 | 09:37 PM
shafrs3's Avatar
shafrs3
Nope, that doesn't work either when searching archives, no match.
Besides, that's 2 three letter words.
Old Nov 22, 2007 | 10:00 PM
RodTeq's Avatar
RodTeq
ToolMan
has anyone looked into the Boss Efi?
http://www.retrotekspeed.com/
Old Nov 22, 2007 | 11:13 PM
CorvetteDave01's Avatar
CorvetteDave01
Yeah, the proflo intake was ported and welded for some more material, to match it with the AFR 210 ports. The machine shop said it should flow enough for 600 hp as did Edelbrock, no way to tell till I get done tuning it though. Motor won't put that out anyway.
Old Nov 23, 2007 | 12:45 AM
Jayson77's Avatar
Jayson77
Not to jack the post or anything-
Most EFI kits seem too far out of my price range. Though I could be looking in the wrong places. What would you say the average cost would be?
Old Nov 23, 2007 | 02:07 AM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
There are a couple of good books discussing junkyard EFI swaps. Might as well take advantage of several zillion dollars of GM engineering - and about a zillion hours of garage tinkerers modifying them.
Old Nov 23, 2007 | 08:55 AM
shafrs3's Avatar
shafrs3
Another satisfied Holley 950 owner here.
Old Nov 27, 2007 | 06:23 PM
Z-man's Avatar
Z-man
Two 3 letter words satifies the 3 character minimum. I put in "efi efi" and got 192 hits from the archive in the C3 forum alone. Are you using advanced search?
Old Nov 27, 2007 | 07:57 PM
shafrs3's Avatar
shafrs3
This is what I did tonight exactly, I click on the search drop down button, click on the bottom for the advanced search option. A new page opens where I type in "EFI EFI", directly below that I select "search entire posts". I move to the bottom and uncheck the current and check the archives boxes, I then move to the right and select c3 Tech/performance and hit search and get a "sorry - no match..."
Then I try different combinations of having the current/archive boxes checked along with the search titles/entire posts and I start getting more results still querying the C3 tech/performance section, 143 results at the most.
I then go back to my original search criteria and I now get 143 results . It's as if my laptop is not sending the request that I typed in the search box in the first attempt, as if what was sent is being received corrupted.
I've been using the search function ever since I joined with no problems. I usually visit the forum from the same laptop, I may have an equipment problem.
Old Nov 27, 2007 | 08:23 PM
Red 71's Avatar
Red 71
From: Melbourne, Fla. 6 months- New Middletown, Ohio 6 months
Originally Posted by burners
I installed a Holley Commander 950 EFI and I love it. It is very easy to tune and it has great throttle response.
Burners, what type of pump are you using? Looks like what I need for a TPI setup I am putting in a 66 Nova.
Thanks!
Old Nov 28, 2007 | 12:30 PM
  #33
burners's Avatar
burners
Cruise-In IV Veteran
Cruise-In V Veteran
Red 71, I answered your e-mail but for everyone's benefit I'll post here as well. The pump came with the Holley kit but they sell them seperately.
http://www.jegs.com/webapp/wcs/store...10002_54876_-1
Old Dec 2, 2007 | 06:17 PM
  #34
KJL's Avatar
KJL
Thanks for the input, maybe I will try to put one together, can't justify dropping 3 grand. I have already put way more money into it than ever planned.
Old Dec 2, 2007 | 06:51 PM
  #35
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
I think the Corvette Fever TBI install cost less than $200. I wish I could remember which issue the article was printed in.
