Remove fuel tank strainer?
Old Nov 16, 2007 | 08:26 PM
74ZZ430's Avatar
74ZZ430
Default Remove fuel tank strainer?
Does a clean fuel tank strainer create much restriction, anyone leave theres off? I been fighting a fuel pressure issue. Since it's on the suction side of the pump and its hard for a mechanical pump to pull fuel is there any advantages to leaving it off. I realize that more dirt could get thru , but my tank is clean and I run a larger fliter in front of a Eldelbrock pump.
Old Nov 16, 2007 | 09:17 PM
itsonlyairandfuel's Avatar
itsonlyairandfuel
I'm not running one, but I have a Good filter in front of my electric pump. Ron B.
Old Nov 17, 2007 | 12:16 PM
BKbroiler's Avatar
BKbroiler
A mechanical fuel pump is a suction pump, so "pulling" gas is really what it does. I dropped the tank on my 77 to check the sock, it wasn't bad but I changed it anyway. I use only a stock pump with no problems.
Old Nov 17, 2007 | 12:21 PM
...Roger...'s Avatar
...Roger...
Its a suction pump all right. I had one suck so hard it crushed the tank so bad that when I opened the lid to remove gas cap the cap was at 90*.
Old Nov 17, 2007 | 05:02 PM
BKbroiler's Avatar
BKbroiler
Thats amazing. I changed my cap to the vented type. I can't see any reason not to use a vented cap. It should prevent that type of thing.
Old Nov 17, 2007 | 10:06 PM
chris75stingray's Avatar
chris75stingray
i left mine off when i had the tank out. also check the rubber lines from the tank to the hard lines, they might be kinked
Old Nov 18, 2007 | 07:32 AM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
GM put the strainer on for a reason and, as you say, it is there to filter dirt from gas. If everything is working properly, this sock shouldn't be a problem. When they get old, however, they do require changing.
To Remove fuel tank strainer?
