Front caliper Pad Problem
Old Nov 16, 2007 | 09:23 PM
mikep3's Avatar
mikep3
Default Front caliper Pad Problem
Have installed new caliper, rotor and pads. There seems to be no space on the inboard side and 1/4" space on the outboard side.
Are there shims to move the rotor out and are ther shims to help with run out?
http://www.shutterfly.com/view/pictures.jsp
Mikep3, 78 Silver Anv. L48 4spd.
Old Nov 16, 2007 | 09:29 PM
sly vette's Avatar
sly vette
Sounds like you may have the wrong rotors.
Mark
Old Nov 16, 2007 | 10:22 PM
wombvette's Avatar
wombvette
Mark
Yep, probably got a rear on that front.
Old Nov 17, 2007 | 09:51 AM
mikep3's Avatar
mikep3
Checked with NAPA, I have the correct rotor part number and there is not a hole for the rear brake adjust.
I will recheck the old rotors which I thought one was worped, but it just needed shimming.
If you know were to get shims for rotors, let me know.
Old Nov 17, 2007 | 10:06 AM
Corvette Engineering's Avatar
0Corvette Engineering
Former Vendor
That doesn't sound right. Never heard of anyone needing to do that before.
I agree with them possibly being rear rotors. ( or at least machined that way)
Old Nov 17, 2007 | 10:09 AM
wombvette's Avatar
wombvette
Check the thickness of the rotor at the center area near the studs. Compare that to the one you took off. Some of those replacements do not work correctly, but NAPA is usually a good source. The shims can be made from brass shim stock. I use 3 and 5 thousands. Just make washer from the stock and place on the stud where necessary.
To Front caliper Pad Problem
