Lifter question
Old Nov 17, 2007 | 10:22 AM
pauly1119's Avatar
pauly1119
St. Jude Donor '06-'11
Default Lifter question
My friend just purchased a 65 chevellemwith a 327 and the Rockers on the driver side are hitting the valve cover, they are rubbing the side of it. We pulled the valve cover off and they don't look bent they just are sitting a little high? Any ideas?
Old Nov 17, 2007 | 10:55 AM
avner's Avatar
avner
Hi
Do you know if the rockers and the push rod are original?
maybe you need high valve covers .
Avner
Old Nov 17, 2007 | 11:53 AM
pauly1119's Avatar
pauly1119
I just spoke to him, he said they are orig and one looks much higher than the others.
Old Nov 17, 2007 | 12:41 PM
okinawa86vette's Avatar
okinawa86vette
If it's all original, it probably has press in rocker studs. You'll want to check to see if it's pulled itself out of the head. That's the reason all aftermarket heads have screw in studs.
Chris
Old Nov 17, 2007 | 01:28 PM
pauly1119's Avatar
pauly1119
Can he buy screw in studs and replace the stock ones? What is involved? CAn the engine recieve screw in ones with no mods? Should we replace the rockers as well. Also is it safe to drive it the way it is? Thanks for all the help.
Old Nov 17, 2007 | 08:03 PM
pauly1119's Avatar
pauly1119
ttt
Old Nov 17, 2007 | 09:04 PM
69autoXr's Avatar
69autoXr
No, the heads need to be drilled and tapped to use screw in studs. The heads will have to be removed for the machining.
Old Nov 18, 2007 | 09:38 AM
pauly1119's Avatar
pauly1119
Old Nov 19, 2007 | 10:13 AM
okinawa86vette
Sorry, I didn't get back on the forum for a few days. What 69AutoXR said is right on.
I wouldn't drive the car the way it is.
C
Old Nov 19, 2007 | 07:38 PM
pauly1119's Avatar
pauly1119
C
thanks for the help. I will pass the info along.
To Lifter question
