Wipers...
Old Nov 17, 2007 | 09:20 PM
jerrylee's Avatar
jerrylee
Default Wipers...
Hey guys when I turn my wipers on they don't come on for at least 5 min. or so...Should I replace the motor or could it be something else...Thanx...Jerrylee///
Old Nov 18, 2007 | 04:10 PM
mikep3's Avatar
mikep3
Default Do the basics
Check to see if you have 12 vots at the motor.
Check to see if you have a good ground at the motor.
Old Nov 18, 2007 | 05:43 PM
wombvette's Avatar
wombvette
Get a spray can of cleaner and clean the gearing mechanism that operates the mag switch. Its under the cover. The old grease is stiff.
To Wipers...
