Pulling the Engine
Old Nov 20, 2007 | 11:19 AM
hicswa's Avatar
hicswa
Default Pulling the Engine
I would like to pull the engine out of my 1975 coupe. Can I pull it with the manual trans still attached?
Thanks Danny
Old Nov 20, 2007 | 11:33 AM
Durango_Boy's Avatar
Durango_Boy
Thanks Danny
Yes, but you run into room issues a lot easier. When pulling both together, while it can be done, it's easier to take the hood off and go at it from more of a forward angle.
Old Nov 20, 2007 | 12:14 PM
The Spark's Avatar
The Spark
That is the way I did it. Remove hood, radiator, and radiator support and you have plenty of room.
I've got pictures on my website pulling 454 w/ manual trans out of my 72.
You need an engine leveler.
I pulled and installed engine/trans by myself.
Allow lots of room in front of your Vette. My garage wasn't big enough so I had to push the car back after the trans cleared the body.
Old Nov 20, 2007 | 12:19 PM
TopGunn's Avatar
TopGunn
I did my 75 by myself with the engine/transmission attached. I removed the right front wheel and positioned the hoist to the side.
Old Nov 20, 2007 | 01:06 PM
burners's Avatar
burners
Cruise-In IV Veteran
Cruise-In V Veteran
I did the same as TopGunn. As the engine clears the radiator support I start pulling the hoist towards the front. Once the pans clears and the tailshaft is past the firewall then just level it out and pull it across the fender. A leveler is definitely needed. I usually remove and install the engine/tranny as a unit. It's just easier to get the clutch aligned and everything torqued properly when it is out of the car.
To Pulling the Engine
