Timing Recommendation
Old Nov 21, 2007 | 11:07 AM
c3andc5's Avatar
c3andc5
Default Timing Recommendation
I have a 73 L82 with a slightly more radical cam then a stock L82. Timing is currently set according to stock specs at 8 deg BTDC, and it's running a little rough. How far should I bump up the timing?
Old Nov 21, 2007 | 11:19 AM
Durango_Boy's Avatar
Durango_Boy
Aggressive cams tend to have bad idles. I don't think timing will get you much of a better idle without affecting driving performance.
Old Nov 21, 2007 | 11:48 AM
70ZZ3 96LT4's Avatar
70ZZ3 96LT4
Default vacuum advance
Do you have fulltime vacuum advance and verified that your vacuum advance unit is holding vacuum?
Old Nov 21, 2007 | 11:52 AM
desi's Avatar
desi
Timing at idle - 15-18 degrees (Vaccum disconnected)
Total timing of 36 degrees, all in by 2500 -3000 rpm
Total with vaccum connected not to exceed 52 degrees
Old Nov 21, 2007 | 12:24 PM
SteveG75's Avatar
SteveG75
Factory idle numbers were set to pass emissions. I don't know about you but I don't drive my car at idle.
Here is a link to Lars' tuning paper:
http://www.corvettefaq.com/c3/HowToSetTiming2.doc
Old Nov 21, 2007 | 12:56 PM
Muddywaters's Avatar
Muddywaters
Follow Lar's paper to a tee...OHhhhh, and hang on Muddy
Old Nov 21, 2007 | 03:43 PM
c3andc5's Avatar
c3andc5
Yea, I pretty much have given up on getting my curb idle perfect, but I am concerned about the mild pinging (knocking) when I get into the excelerator hard. I bumped the timing up to 12 deg BTDC and it improved.
Old Nov 21, 2007 | 03:45 PM
c3andc5's Avatar
c3andc5
Yes to both. I have eliminated any vacuum issues and distributor problems (points, rotor, cap, etc).
Old Nov 21, 2007 | 03:50 PM
c3andc5's Avatar
c3andc5
What source do those numbers come from?
Old Nov 21, 2007 | 03:57 PM
c3andc5's Avatar
c3andc5
That write-up from Lars makes sense to me and I had never considered setting the timing that way. I'll give it a shot.
To Timing Recommendation
