'76 Door hinge Spring Install
Old Nov 21, 2007 | 09:06 PM
pete44's Avatar
pete44
Default '76 Door hinge Spring Install
Hello....Tried but had no luck (even with "helper" tool)...Anyone have procedural (with pics)????...Zip Corvette sent no instructions..........Thanks,Pete
Old Nov 22, 2007 | 11:57 AM
Scott Marzahl's Avatar
Scott Marzahl
ZIp has it online in their tech section online, or Google C3 Corvette door spring replacement for several hits.
Old Nov 23, 2007 | 09:02 AM
joe@zip's Avatar
joe@zip
Platinum Supporting Vendor
This should help
http://www.corvettemagazine.com/2005...hinge-lead.asp
__________________
Zip Corvette Parts and Accessories - Corvettes Are All We Do!
Selling Quality Corvette Parts & Accessories Since 1977
Corvette Parts Catalogs | Subscribe to our newsletter
Corvette Tech Articles
Old Nov 23, 2007 | 08:17 PM
pete44's Avatar
pete44
Originally Posted by PriceatZIP
Thanks!...I'll give it a look....Pete
Old Nov 23, 2007 | 08:55 PM
Rolling Thunder's Avatar
Rolling Thunder
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude Donor '03
In addition to the procedure outlined below, there is somewhat of a trick to installing the spring. It's been a while since I did it, but in addition to your bent screwdriver, your most important tool is the door itself. Instead of trying to do all of the "spring twisting" with the tool, let the door do the work. Changing the open/close position of the door while forcing the spring makes the job last a total of about 5 minutes. Set it up as shown in the sketch when you start to twist the spring, slowly open (or close) the door a few degrees. One direction will work in your favor and the other against you. I think it will make better sense when you try it and see what I'm talking about.
Good luck,
Dave
To '76 Door hinge Spring Install
