Tranny swap
Old Nov 22, 2007 | 01:17 PM
Red 71's Avatar
Red 71
From: Melbourne, Fla. 6 months- New Middletown, Ohio 6 months
Default Tranny swap
I tried to do a search on this but apparently did not use the correct search terms.
On a auto to std swap (71), is it necessary to pull the steering column in order to make the peddle swap or is it just a lot easier with the column removed. As I am writing this I also happened to think about whether there would be any ignition lock issues. I am sure those of you who have done the swap have the answers I am looking for.
Thanks ahead of time.
Old Nov 22, 2007 | 06:05 PM
Artsvette73's Avatar
Artsvette73
I believe you have to pull the column.You have to remove the dash pad any way. It's not all that hard
