Harmonic Balancer
Old Nov 26, 2007 | 03:35 PM
pdege's Avatar
pdege
Default Harmonic Balancer
I have to replace mine and a search of the archives turned up the fact that someone said you only have to remove the fan, pulleys and belts to make the change.
Anyone else have success with this method?
BTW 1980 car
Old Nov 26, 2007 | 03:42 PM
Durango_Boy's Avatar
Durango_Boy
That's correct. You need to get all the belts off of the crank pulley and that means fan, water pump pulley, and loosening the accessories to get the belts off.
The crank pulley is easy to get off with just a few bolts holding it on. There is a main balancer bolt int he center that must come out, and then you will need the use of a balancer puller to remove the old balancer.
Upon returning the balancer puller kit, you'll want to pick up a balancer installation kit to put the new balancer back on.
Tip: Lube the installation very well with thread oil before installing the new balancer. You don't want the threads buggering up. Also, install the balancer fully against the crank shoulder. Basically go until it stops. Then, align the rest of the pulleys to the crank pulley, and if you need to shim the crank pulley to get everything lined up right.
Old Nov 26, 2007 | 04:04 PM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
It's impossible to do the job with the belts, etc. on the car.
Old Nov 26, 2007 | 05:12 PM
pdege's Avatar
pdege
Now with the balancer off can I sneak in a new seal without further disassembly?
Old Nov 26, 2007 | 05:19 PM
joehalford01's Avatar
joehalford01
it's time for another frame off thread, i can't wait to see how this car turns out
Old Nov 26, 2007 | 05:50 PM
TimAT's Avatar
TimAT
Yep, Just pack the cavity on the back of the new seal with grease and tap it back in. That will keep the garter spring from popping out.
Old Nov 29, 2007 | 02:27 PM
iveym5's Avatar
iveym5
TimAT - Great idea to keep the garter spring (I never knew that they were called that!) in. It's always maddening to find out that it popped out because you don't know until you get everything all put back together and it leaks!
Old Nov 29, 2007 | 04:47 PM
RunningMan373's Avatar
RunningMan373
To Harmonic Balancer
