Evaporator Replacement?
Old Nov 28, 2007 | 11:18 PM
flynhi's Avatar
flynhi
Default Evaporator Replacement?
During winter garage time I'm going to tackle my AC one more time.
Here's what I've done so far:
Sanden Compressor
new condenser
Dual Spals
C4 fan
insulated and sealed evap case
sealed ducts
13 v to fan
R134
Cleaned leaves, etc from evap case
Replaced heater coil
I still have low volume and inadequate cooling
So, all that's left is the evap coil.
Is there a better evap coil out there that is a better match for the Sanden, is more efficient or flows more air?
Is there a smaller heater coil that will allow more conditioned air to pass?
Any help appreciated.......
Old Nov 29, 2007 | 03:33 AM
HamadUP's Avatar
HamadUP
St. Jude Donor '08
I read somewhere that Sanden 508 has less displacement that the A6 compressor, so if you swap in a 508 you'll lose a little of cooling capacity.
Old Nov 29, 2007 | 07:23 AM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
The original a/c systems work fine on the C3's providing everything is in proper working order. Air volume, however, is generally on the low side, but your bigger fan may help that. Other problem areas regarding cooling are the rear hood seal not sealing properly and allowing engine heat into the air mix, engine heat entering thru the firewall, and a faulty heater control valve located in one of your heater hoses. You also want to make sure you have the proper 134A charge in the system which is generally 75% or so of the R12 fill.
Old Nov 29, 2007 | 08:10 AM
S489's Avatar
S489
is your new condenser a cross-flow type?
Old Nov 29, 2007 | 11:31 PM
flynhi's Avatar
flynhi
Hi Jud,
Good tips. Real hood seal in place. Firewall plugged and insulated. Manual valves installed on heatr supply and return lines. Fully charged by a pro.
Old Nov 30, 2007 | 07:34 AM
Jud Chapin's Avatar
Jud Chapin
I doubt the evav. core is your problem unless it is clogged up but you say you checked it. Did you have it completely out when you checked it. When I changed mine, all the leaves and crap were at the bottom. How are your pressures? Is the tech who charged your system satisfied with them and what does he have to say about your problem? For sure something is amiss and perhaps if all else fails, take it to a good Vette tech who really knows a/c. Just so you know, my totally stock '76 blows 40 degrees at the vents and I live in South Florida. It could use more air volume, but overall it does the job quite well. I wish you luck, Will, in getting the problem solved.
Old Nov 30, 2007 | 10:45 AM
Patrick73's Avatar
Patrick73
http://forums.corvetteforum.com/show....php?t=1715489
Read this thread. When I addressed the "radiant heat issue" after doing all the normal AC fixes--as you have done--my AC and hot air thru vent issues were all solved.
Old Dec 1, 2007 | 01:35 PM
flynhi's Avatar
flynhi
I have insulated the exterior of the evap box. I'll take a look at insulating the lines.
Tks,
W.
Old Dec 2, 2007 | 10:13 PM
flynhi's Avatar
flynhi
Ttt
Old Jul 10, 2012 | 11:00 PM
brrujo's Avatar
brrujo
Why change compressors?? The A-6 is 13 cu inches and probably one of the best compressors ever made. The 508 sanden is only 8 cu in. The A-6 has a internal oil pump with an oil sump. The sanden has neither. It depends on oil flow with the refrigerant to keep it alive. I have been in the mobile HVAC industry for years and seen very few cooked a-6's. Seen more locked up sanden's than I can count!!
Old Jul 10, 2012 | 11:06 PM
flynhi's Avatar
flynhi
I tried everything imaginable to get my 71 vert cool and finally gave up and sold it.
In retrospect, I should have kept the OE A6 for more capacity.
Old Jul 11, 2012 | 09:39 AM
Roco71's Avatar
Roco71
Small thing perhaps but do you have the evaporator drain tube in place? If not heat from the exhaust can get into the evaporator box.
http://www.zip-corvette.com/ProductD...GR-SR&CTitle=&
Old Jul 11, 2012 | 11:02 AM
flynhi's Avatar
flynhi
[QUOTE=Roco71;1581286921]Small thing perhaps but do you have the evaporator drain tube in place? If not heat from the exhaust can get into the evaporator box.
If this is not in place, you have a 1"+ hole in the bottom of the evap case wasting cooled air.
To Evaporator Replacement?
