So when are you selling your AFR heads going to Pro comp heads
you can save some money up front.
Well the bigger issue is the part where the seats are machined out to the aluminum. You probably wouldn't really notice it unless you disassemble the heads to check them before installing or bought bare castings. The varying chamber size would be a huge issue to the durability also. Would create an out of balance situation and possibly detonation issues on the small chambers. Again the guy putting them on out of the box would not know. You would have to CC the chambers to find it. I think ALL heads should be disassembled and checked closely before installing. My AFR's were too tight on the intake guides when disassembled and checked. Clearance was .001. Had to hone the guides on them. If I were to have just thrown them on out of the box could have possibly stuck a valve when brought up to operating temp. The chamber size, valve seats, castings, valves and flow were almost perfect though.
Yep I read it all thats why I said save money up front, sounds like
there heads are so messed up you could end up with engine damage
and costly engine repairs.
You get what you pay for, when I buy heads I want them made in a country where the workers are familiar with the use of the end product. Brodix IK series or Canfield heads are reasonably priced USA made parts that WILL make MORE HP and last longer. There is metallurgy, chemistry, and maching aspects to making a sucessful cylinder head and if you think China has the edge on these science, be my guest and buy them on Fleabay for under $500 a set (probably going down to $400 next week )
A buddy of mine got a set of those heads and regrets using them. You can definitely tell the difference in the metal used versus the more expensive heads.
I wouldn't bet on anything from China going down in price as we are seeing as much as 30% increases from items made from steel and Aluminum from there. The good new is the USA products should not go up as much.
Well, I see the Boatstoreonline pulled their writeup ripping these heads. Must not have wanted to spend the legal fees. Thought we had freedom of the press in this country.
