1977 Oil Pan
Old Dec 1, 2007 | 02:03 PM
gtexas's Avatar
gtexas
Default 1977 Oil Pan
I am going to be putting a 383 in my 77 and I will be replacing the bent and beat oil pan thats in it. I have a couple pans in the shed. Does a Vette take a special pan? I have two Marine 6 quart pans too. I wonder if they would work.
Old Dec 1, 2007 | 02:40 PM
Durango_Boy's Avatar
Durango_Boy
So long as it's a rear sump pan you should be fine.
Will you post a pic of the marine pans? I'm interested in those.
Old Dec 2, 2007 | 01:27 PM
gtexas's Avatar
gtexas
Default 1977 oil pan
Look just like a standard pan but 1 quart deeper sump. I didn't know what I had till I build a motor,,, put in 5 quarts,,,,Primed the oil pump and check the oil and it was a quart low.
To 1977 Oil Pan
