81 A/c
Old Dec 1, 2007 | 11:07 PM
BERIN's Avatar
BERIN
Default 81 A/c
Can't get the A/C to come on, I have replaced the A/C relay and all switches on the center console and the fuses are ok. Any sugestions?
Old Dec 1, 2007 | 11:29 PM
colin75's Avatar
colin75
What Do You Mean By Wont Come On? Interior Action Or Compressor Engagement? While Working With My A/c Issues I Learned That The Compressor Wouldnt Engage Until Enough Refrigerent Pressure Was In The System.
Old Dec 2, 2007 | 12:05 AM
66roadster427's Avatar
66roadster427
Berin,
with the engine running and the A/C turned on, check for power at the low pressure cycling switch which you can find by following the wire back from the compressor - it is part of the freon line. If there is power on just one side then the switch is faulty or you are low on freon. If there is power on both sides of the switch then check for power at the coil on the compressor. If there is power at the coil and it isnt kicking in it is faulty, and if there is no power at the coil then check the line from the switch.
Post what you find and if it is something else we will figure it out!
Cheers,
Brett.
Old Dec 2, 2007 | 05:23 PM
BERIN's Avatar
BERIN
Checked levels they seem ok, I have power to all switches I dont understand the coil at the compressor I just have two wires going into the compressor behind the pully and they are both hot. I did replace the blower cut out and tried the old one still nothing also replced fan switch on the console it was just getting old and the original got to where it would blow on just two settings. Still not blowing inside.
Old Dec 3, 2007 | 09:53 PM
BERIN's Avatar
BERIN
Just found the problem, aux fan was hooked up wrong from the engine builder i went to. would like to put in a new blower motor but looks like a pain. Thanks for your replys
To 81 A/c
