76 Vacuum Filter
Old Dec 3, 2007 | 12:29 PM
pete44's Avatar
pete44
Default 76 Vacuum Filter
Hello..Ordered a new vacuum filter..goes before check valve...Car did not have one on before..Just the 3 port check valve...The filter is plastic/ white with one port on each end...I read in a vacuum paper from here states" pay attention when taking old filter off to install new one"..There is no clue/markings on which direction filter goes...I blew into it and it seems the same pressure on both ends..Help!..Thanks,Pete
Old Dec 5, 2007 | 09:38 AM
pete44's Avatar
pete44
Old Dec 5, 2007 | 03:18 PM
billsfan's Avatar
billsfan
It can go in either way. The orientation only matters if you are re using your old filter.
Old Dec 6, 2007 | 09:43 AM
pete44's Avatar
pete44
Thanks for the info..Now on the other hand...The vacuum line that will run to this filter and presently the 3 port filter is connected to back of carb...I had a friend email me a pic of his '76 engine and it runs to a "valve" behind carb that screws into engine..I think this "filter" helps filter out sediment into engine....My confusion is that my "valve" behind carb runs to a metal line which I found out may go to shift assist on transmission....Thanks for anymore help.....Pete
Old Dec 6, 2007 | 10:13 AM
SARASOTA SAM's Avatar
SARASOTA SAM
Had mine off yesterday. It caused me a scare the day before.Headlight pods lifted real slow then one stuck up one went down on shut off.Wiper pod on 72 wouldnt open. NEARLY started a full troubleshoot of both vacuum sysems. Guess what! Had'nt cleaned that sucker out for 2 years checking back on my records.AMAZING just how much fine black dust came out it was fully blocked up.Now everything back to normal again.
POINT IS ITS A EASY THING TO OVERLOOK KEEPING IT CLEAN.
Hope this saves you and other readers some time in the future SAM.
Old Dec 6, 2007 | 11:17 AM
...Roger...'s Avatar
...Roger...
No just the opposite.When the engine is not running it keeps fuel vapors from seeping into the vacuum system.
Old Dec 6, 2007 | 01:15 PM
pws69's Avatar
pws69
I believe that would be the [other] job of the check valve and the filter serves as he has stated.
Old Dec 6, 2007 | 01:18 PM
...Roger...
Hmmm I thought the filter protected the check valve and the vacuum hoses and etc.
edit-does make sense though if the check valve was good it couldnt get passed it-could be wrong-sorry
Edit again-Just learned something today.All the books say the filter does in fact keep particles from entering the engine.Not sure how I got it in my head the filter protected the vacuum system from fuel vapors.Sorry for the misinformation.:o
Old Dec 6, 2007 | 02:09 PM
pws69's Avatar
pws69
Yep, it can be a little fuzzy! The filter is there to primarily prevent any foreign objects from getting sucked into the intake. The check valve is SUPPOSED to
- make sure that only Vacuum exists on the "demand" side of it
......(like when you stand on it, vacuum would go away without it)
- stop the vacuum system from loosing vacuum after shutoff
......(yea, right maybe 2 seconds!)
- keep the fumes and potentially fuel from being sucked into the vacuum system.
Old Dec 6, 2007 | 02:39 PM
...Roger...
Not sure where I came up with that mumbo jumbo.I seem to remember a person or a company saying you had to replace the filter when buying a new check valve to protect the check valve.For some reason I thought it was Paragon,they always had those little helpful hints printed all over their catalogs.Maybe its just the old age !!!!!
To 76 Vacuum Filter
