What is this?
Old Dec 6, 2007 | 12:50 PM
pete44's Avatar
pete44
Default What is this?
What is the "valve" that sits in front of distributor (above #8 cyl)?..the rubber line I was told runs to transmission ...via metal line...Thanks,Pete
Old Dec 6, 2007 | 12:58 PM
Durango_Boy's Avatar
Durango_Boy
It's just a vacuum tree. It might sever as a check valve but I do not know that for sure. Most times a tree is just a nipple for supplying vacuum to a small diameter tube from a large diameter port.
Old Dec 6, 2007 | 01:00 PM
dewcustom's Avatar
dewcustom
it is just a vacuum port for manifold vacuum
Old Dec 6, 2007 | 05:33 PM
justanotherdoe's Avatar
justanotherdoe
agree - and is connected to the automatic transmission modulator via the metal line.
Old Dec 11, 2007 | 08:48 AM
pete44's Avatar
pete44
Thanks for the replies...and as I suspected (and was told) matches the above comment...I have dug through books (manuals and parts) and still do not know the "official" name ...I need a replacement and it is aggravating not knowing its name ....Anyone else?.....Thanks,Pete
Old Dec 11, 2007 | 10:24 AM
sweethence's Avatar
sweethence
From: Wilmington DE, Drive it like you stole it, 68 327 4 speed coupe
its called an intake manifold vacuum fitting and has a port count
i.e http://www.ecklers.com/product.asp?p...0&dept_id=1273
Old Dec 11, 2007 | 01:23 PM
pete44's Avatar
pete44
Thanks Sweethence!....I was wondering now if I need the single or 2 port vacuum fitting?....If you look closer at my pic someone capped off the top of the vacuum fitting and have only a single connection to transmission modulator via the metal line...(I wonder if that was a smog/AIR connection at one time that is capped off now..maybe someone on this message board has a good pic of their '76 and connections,,,,,Thanks,Pete
Old Dec 11, 2007 | 01:36 PM
sweethence's Avatar
sweethence
I see you have a 76, and depending on your options, the things that usually draw vacuum from that fitting are
1. headlight system (check valve required)
2. brake MC Booster (check valve required)
3. the trans fitting you have there (not sure on check valve)
4. EGR equipment (if present not sure about 76 EGR)
the number of ports will depend on your cars specifics
but each of those should have a dedicated port
the AIR system aka smog pump had no tie to the intake port, as it ran off of a dedicated pump of its own
Look to me like you should get an AIM for your year car, a few things look misrouted to me
cheers
tim
Old Dec 12, 2007 | 08:55 AM
pete44's Avatar
pete44
cheers
tim
Thanks!....What is this "AIM" and where can I purchase one?....Thanks,Pete
Old Dec 12, 2007 | 09:14 AM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
Assembly Instruction Manual used by the factory to put cars together. You can pick one up on Ebay or most Vette flea markets.
Old Dec 12, 2007 | 09:24 AM
sweethence's Avatar
sweethence
like the man said factory assembly manual
I recommned that plus the service manual for your year car, and a chevrolet by the numbers, book, as well as the restoring your corvette book.
all are avaibale on ebay. But I got mine form Corvette central, they seem to have the best pricing of the catalogs
also if you call GM and give them your VIN, they will send you a restoration package that has everything about your year car as well as GM licensed vendors and enough info to write your own book!!!!!!
A bunch of us here did that a while back, and its FREE
cheers
tim
Old Dec 12, 2007 | 09:26 AM
Jud Chapin's Avatar
Jud Chapin
cheers
tim
Got a phone # for Gm, Tim?
Old Dec 12, 2007 | 09:31 AM
Jud Chapin's Avatar
Jud Chapin
One other thing, Pete. Be careful where you pick up an AIM. Many of these are of very poor print, the result of being copied over, and over, and over again.
sweethence's Avatar
sweethence
from the archives
You can get a "restoration package" at no cost from GM/Chevrolet. Sinply call the Chevy/Geo customer assistance hotline at (800) 222-1020 or 810-696-4800. Have your VIN handy, as they'll ask for it. The contents of this package varies by year. Call now before they start charging!
If your car was originally registered in Canada. you will have to call GM of Canada at (800) 263-3777. GM Canda wants $40.00 plus tax for the restoration package, so try the US number first!
this is a great package, with every specification on the corvette included, I was amazed at the level of detail, a MUST have. and it only took like 3 or 4 days to arrive in the mail. when I did it, they actually sent me the 67 package by mistake, I called them back and 3 days later two 68 packages arrived
I should would give it away, but since its free its kinda hard
I just called and its still free
Cheers
tim
Old Dec 12, 2007 | 09:41 AM
Jud Chapin's Avatar
Jud Chapin
from the archives
Cheers
tim
You the man, Tim. Thanks!
To What is this?
