I have never installed a upper control arm bushing. At a glance it looks like "pop out-pop in" . However I know thats too easy. Vehicle weight is a factor.
You have to remove the arms to replace the bushings. There are several ways to replace them. Lars wrote and excellant paper on this you can probably find. I use an air chisel to pop them out.
I spend probably 1/2 hour each bushing drilling the rubber out then beating and pulling the metal sleve out. I took them into a shop to have the bushings pressed in and he said he would have pulled them out for the same price anyway. 40.00 to press all of them. I wouldnt reccommend trying to do it. You cant press them anyway unless you have a press.
From: San Diego - Deep Within The State of CONFUSION!
Originally Posted by The3
I would pull the control arms and clean and paint them. You don't need to replace the metal cups, just replace the rubber bushings.
Just order new arms from VanSteel. They come powder coated already. Not to mention they have NEW ball joints, and NEW bushings already installed.
Plus, you get to drive the car until the box gets there. And from the time it gets to you its just a half a day to get your old cores in the same boxes and shipped back to VanSteel.
I did that and am Soooo glad. Saves a lot of effort. It's been two years now, and the control arms still look new. I got new springs at the same time, and shocks to complete the deal.
You're right, it's never that easy. I had to burn out the rubber from mine and then use an air hammer/chisel to get the sleeves out. Good Luck!
If you're going to do that, it's much faster to skip the "burning" step.
What is with everyone burning/drilling the rubber before prying out the shell? If you're going to take the shell out, just remove everything as one lump.
I froze my new shells in the freezer overnight, then set them in place with a 2# drill hammer. (I supported the flange so nothing would get bent).
Originally Posted by corbyscott
Pull your arms off and take them to Pep Boys they will press the old bushings out and the new ones back in for around $85 labor.
And probably bend your arms in the process.
Ive heard freezing them works well. I didnt hear about it til after I was done. As far as getting the bushing out without removing the rubber. I dont have a press. Please tell me how to get the whole piece out together.. I tried and others I talked to said this was the only way they know.
I do most everything myself, but there are times when I would rather pay 40 bucks. This was one..
I air chiseled them out,and pressed my new ones in with a bottle jack and a home made press made with scrap metal I had laying around I've done them before with a hammer also the hardest part was keeping them going in straight
I walked seven of the eight bushings out with a cold chisel and a 2lb. drill hammer, with the rubber intact. I made each blow as close to 1/4 around the shell flange from the last blow as I could. I drilled/burned/cut the rubber out of the first one I did, then used the chisel to pop the shell loose. Spent almost 45 minutes on that one. The other seven took about an hour combined. The trick was to move around the edge so that the shell came out as straight as possible. Too much angle and it would bind badly.
That's right!
Do a search ... plenty posts on it been beat to death. SAVE old outer shell in place & do not damage it! Hog out rubber w/ hole saw ... replace remainder w/ stuff from energy suspension poyurethane kit. This method works only when replacing old rubber w/ new poly. Use search terms hole saw hog bushing .
I rebuilt my control arms with new bushings, ball joints and bumpers - the whole nine yards. It was my first time and I did everything myself. I drilled out the old rubber with a small drill bit several times until the rubber was finally gone. I used an air hammer to remove the metal shells. I put the new metal shells in the freezer beforehand and had my dad hold the lower control arms on the bench while I pounded them in with a hammer and socket...worked pretty good. Just make sure you don't bend the control arms when installing them - I had to replace one from previous damage combined with my mistake on installation:o Look good as new now! Good luck.
One more thing. When doing the lowers, you have to install one shell and then insert the crosshaft through the arm...then install the outer shell. If you install both shells and then try to fit the shaft in place, you will never get them in! I used poly bushings from VanSteel. I can't remember if you have to do the same things with the uppers as you do with the lowers.
