Gauges for Engine Break-In
Old Dec 9, 2007 | 04:45 PM
ShinodaVette's Avatar
ShinodaVette
Default Gauges for Engine Break-In
I'm doing a frame off on my '81. In the next few weeks I will be finishing up the engine and dropping it in the frame. I'd like to break-in the engine at that point so that if there are any problems I can just take care of them at that time instead of waiting for the car to be complete and then finding a problem.
So, my question is about connecting gauges up to the engine during break-in. Can I somehow connect the stock gauges up to the engine during break-in or would it be easier to just buy a cheap set of mechanical gauges (oil press., water temp, tach) and use them for the break-in. The stock gauges are electric so far as I know so I'm not sure what all I would have to connect up to get them working. Summit sells a pretty cheap set of mechanical gauges but I hate to waste money.
Thoughts?
Old Dec 9, 2007 | 05:18 PM
markdtn's Avatar
markdtn
I would buy cheap gauges from Walmart or similar. Oil pressure and temperature are really all you need. Maybe you can borrow a tach somewhere, but it isn't crucial IMHO. You could take the dash apart and make the stock ones work, but I would rather use mechanical ones for what you are doing.
Old Dec 9, 2007 | 09:21 PM
rponfick's Avatar
rponfick
I just used a cheap oil pressure gauge I had laying around from another project. I used my hand-held infrared temp gun to be sure temperatures did not get out of hand.
Everything worked fine, but that may be because Lars was helping.
Ralph.
To Gauges for Engine Break-In
