TH400 Stuck in Drive
Old Dec 10, 2007 | 02:20 AM
murraybs's Avatar
murraybs
Default TH400 Stuck in Drive
Alright, this is kind of odd, my transmission is doing some funky stuff:
In park, it feels like it's got power to the rear wheels.
In Reverse, the lights come on but the car won't move (acts like it's in park but there's obviously some resistance on the engine)
In Neutral, acts like drive up until about 10mph, then starts acting like neutral again.
In Drive, works normally but now shifts more smoothly than ever.
This started immediately after I brought the fluid level (hot) up to the line on the dipstick. Do these symptoms indicate overfilling?
Old Dec 10, 2007 | 07:51 AM
Ragtop_Rob's Avatar
Ragtop_Rob
St. Jude Donor '17
Did you check it running in neutral or park on a level surface totally warmed up after driving (it is not good enough to just idle it till warm, you have to drive it to get the trans fluid distributed everywhere)?
Did you add anything other than Dextron? When you checked it, was there foam on the dipstick (indicates it is actually over full)
How low was it?
That stuff aside - did you adjust the linkage or anything else?
Old Dec 10, 2007 | 09:22 AM
murraybs's Avatar
murraybs
How low was it?
Checked in park after warmed from driving to my FLAPS (Friendly Local Auto Parts Store).
Put in Valvoline Hi-Mileage Dexron.
Didn't mess with the linkage at all, but after I added some fluid (about a pint as per the recommendations on the dipstick) the trans would act like it was in "drive" in all gears. Park works but the back end squats a bit like it's getting power, neutral acts like drive until about 10-15mph, then it acts like neutral again, drive acts like drive, and reverse acts like park but the engine won't rev as quickly, indicating that the TC is trying to lock up but can't because it's trying to be in Drive and Reverse at the same time.
The stick has froth on it now, but didn't before. I guess I need to drain and fill it and see what that does.
Old Dec 10, 2007 | 09:39 AM
Ragtop_Rob's Avatar
Ragtop_Rob
St. Jude Donor '17
The froth indicates it may be over full. When they get too much fluid in them they whip it around like mad causing the foam - that plays hell on it. When you drain, watch the refill amount.
The ONLY reason I thiught this is when someone rebuilt my TH400 they did not use the correct dipstick tube (from a th350?) and I did the same thing a little while after I got the car.
Old Dec 10, 2007 | 09:41 AM
murraybs's Avatar
murraybs
Did it act the same way?
This car is such a frankenstein that it probably does have a th350 dipstick, or maybe even a 700R4 dipstick for all I know.
Old Dec 10, 2007 | 12:10 PM
Ragtop_Rob's Avatar
Ragtop_Rob
St. Jude Donor '17
Mine could not find first unless it was in neutral and it would not go into second at all. My first thought was damn did I put transfluid in or something else
It was just too full. So I drained everything, added the correct amount and remarked the stick.
I hope this is the same issue - it is an easy fix!
Old Dec 10, 2007 | 06:19 PM
murraybs's Avatar
murraybs
Cool, thats about what I thought. Thanks for the info. While I'm in there I may as well replace the Transmission filter.
Old Dec 10, 2007 | 08:10 PM
70ZZ3 96LT4's Avatar
70ZZ3 96LT4
Default filter replacement
When you replace the filter and remove the old, there should be an o-ring that is on the vertical tube. Look for the o-ring in the attachment cavity if it did not come out with the filter and replace it. If they still sell it, the replacement turbo 400 transmission pan is of so much grearter quality that the original turbo 400 pan. Heavier guage of metal, real good solid piece that is much better at gasket sealing. Torque on the pan bolts is not much to keep from pinching the cork gasket. Without looking it up again I think it is about 11-12 foot pounds.
Old Dec 11, 2007 | 05:25 AM
Ragtop_Rob's Avatar
Ragtop_Rob
St. Jude Donor '17
While I'm in there.
That is the phrase that leads to body off resotrations.....
Old Dec 11, 2007 | 06:18 AM
murraybs's Avatar
murraybs
Been there, done that. I still haven't reassembled my '72 VW. Did some bodywork and "While I'm changing the clutch, I may as well..."
To TH400 Stuck in Drive
