ZZ383 water pump clearance question
Old Dec 10, 2007 | 05:09 PM
yellow94coupe's Avatar
yellow94coupe
Default ZZ383 water pump clearance question
My mechanic has run into a snag with installing the short style water pump onto the ZZ383 even with clearancing. I hear the Edelbrock 8812 fits the ZZ4, but I'm not sure if the zz383 and zz4 are externally identical in which case I'd use that. I also called Edelbrock and they weren't sure if it would fit. Has anyone tried it?
The other option is to grind the pump like numerous people have done. Does anyone have any detailed instructions or pics on where and how much to grind?
Old Dec 10, 2007 | 05:31 PM
cduemig's Avatar
cduemig
I'm not sure what the clearance problem is, but I just installed my 383 and the pulley touched the water pump. I used 4 washers to space out the pulley and did the same for my alt bracket and no clearance issues and everything lines up...
Old Dec 10, 2007 | 05:33 PM
yellow94coupe
They said it wouldn't clear the timing cover. I'm going to run over there after work and take a look for myself.
Old Dec 11, 2007 | 03:27 PM
agent kronus's Avatar
agent kronus
find this info on this website http://www.jegs.com/webapp/wcs/store...10002_98824_-1
If a short water pump is to be used on this engine, there will be clearance problems between the water pump backing plate bolt heads and the composite timing cover used on the Fast Burn 385. Many times this problem can be fixed easily by replacing the bolts on the water pump backing plate with button head Allen bolts. If this approach does not work, the timing cover will need to be replaced with a sheetmetal or any chrome unit. Any small block Chevy timing cover will work on the Fast Burn 385. If the timing cover is replaced, dowel pins are also needed.
dave
Old Dec 11, 2007 | 03:49 PM
yellow94coupe
Yeah, I read that too. From what I understand, this Edelbrock pump is supposed to have a little extra clearance which allows it to fit. People say it fits just fine on the ZZ4 but nobody says for sure if it fits the ZZ383 with the stock cover. I thought I saw that the ZZ4 had a different part number for the cover so I thought I'd see who has done it.
After looking at where it was interfering last night, swapping out the bolts wasn't going to work with the short pump I had. Perhaps it was just that pump was shorter than standard or something.
I wound up buying the 8812 pump so I'll know for sure in the next day or two if it does in fact fit.
Old Dec 11, 2007 | 04:49 PM
tigers123's Avatar
tigers123
Please do as I just bought the 383 short block from gm
Old Dec 11, 2007 | 07:23 PM
Road-Race Vette's Avatar
0Road-Race Vette
Former Vendor
I ran into the exact same problem with a customers zz385 hp 350. I ground down the timing cover bolts(only the ones that were hitting)enough to make clearance.It worked great and there is still enough bolt head in case you need to remove cover.
Old Dec 11, 2007 | 07:58 PM
spedaleden's Avatar
spedaleden
I have a zz4 block with the 8812 pump. It fits with no leaks. Make sure it is the newer version. Produced in the last year.
Old Dec 12, 2007 | 07:00 AM
jerome1979's Avatar
jerome1979
385 Fast Burn with a short cast iron water pump!
to fit this i had to grind head of 1 or 2 bolts! and no cover modification (and if you have trouble cut your seal in a plate of thiker seal plate)
Old Dec 12, 2007 | 11:00 AM
yellow94coupe
It fits. It did require a little adjusting of the pulleys to get the belts to line up properly. He already ground the bolts on the cover for fitting the old pump so I'm not sure if that is required for the new pump. I'll double check and see if any pump grinding was required when I pick it up tomorrow.
Old Dec 16, 2007 | 07:21 PM
yellow94coupe
It doesn't sound like any additional grinding was necessary. It does have a lot more timing cover clearance, but that does require the alternator to be shimmed forward to line up with the pulley.
Old Dec 16, 2007 | 07:52 PM
carriljc's Avatar
carriljc
Default When I installed my cast iron Flowkooler water pump....
on my Ramjet (has the new plastic timing cover) I had to grind down 1 or 2 bolts for the timing cover. I also ground down a couple of areas on the water pump itself (just slightly) so the pulleys would not rub on it....but nothing on the Aft side.
To ZZ383 water pump clearance question
