ugly engine hoist brackets
Old Dec 12, 2007 | 11:43 AM
63mako's Avatar
63mako
St. Jude Donor '08-'09
Default ugly engine hoist brackets
I would like some nice looking, functional engine hoist brackets to mount and leave on the engine. Can't find anything like this. Anybody got some and where did you get them? Maybe something in stainless?
Old Dec 12, 2007 | 11:50 AM
SIXFOOTER's Avatar
SIXFOOTER
I usually just take them off for a cleaner look, but have seen them chromed a couple of times. SS would look good too
Old Dec 12, 2007 | 12:14 PM
yellow 72's Avatar
yellow 72
St. Jude Donor '09
Kind of pessimistic about your build ain't ya
Old Dec 12, 2007 | 02:32 PM
burners's Avatar
burners
Cruise-In IV Veteran
Cruise-In V Veteran
Sorry, I can't help with a better looking bracket. I just don't even use the brackets. I usually bolt the chains to the cylinder heads or use a carb plate.
Old Dec 12, 2007 | 02:41 PM
Scott Marzahl's Avatar
Scott Marzahl
Years ago I wanted to keep the hoist brackets for an engine so I had the stock GM ones chromed which really set them off. However, I prefer to leave them off these days for a cleaner look.
Old Dec 12, 2007 | 03:11 PM
69427's Avatar
69427
From: I tend to be leery of any guy who doesn't own a chainsaw or a handgun.
Just dead weight after the engine is in. What's the point?
Old Dec 12, 2007 | 03:31 PM
63mako's Avatar
63mako
The fuel log and nitrous stuff has to be removed and installed to put the brackets on and off. I really don't want to bolt the chain to the AFR heads and a carb plate is not my choice to pull and install the engine, just looks pretty weak and can't take the chance of a bolt hole stripping or manifold breaking (hand ported tripower). An attractive, functional bracket would be my best option. The stock ones are pretty ugly and chrome against aluminum isn't a good combination either (corrosion). Just thought someone might have seen something that meets the need.
Old Dec 12, 2007 | 03:37 PM
Garys 68's Avatar
Garys 68
Try the marine parts sellers.
Lots of polished stainless/aluminum harware.
Try this link and search "lifting":
http://www.cpperformance.com/search.aspx?advanced=1
Check out these links:
http://www.cpperformance.com/detail.aspx?ID=8155
http://www.cpperformance.com/detail.aspx?ID=8158
Old Dec 12, 2007 | 04:14 PM
63mako's Avatar
63mako
That is what I was looking for. Thanks!
Old Dec 12, 2007 | 11:52 PM
tfi racing's Avatar
tfi racing
www.joesracing.com They make a lot of cool,whizzy stuff I only dream of buying...
Old Dec 14, 2007 | 12:04 AM
dfolse62's Avatar
dfolse62
You know, it's not a Ford. You probably won't ever need them again!
To ugly engine hoist brackets
