Crate motor question
Kenny
That crate motor would definately make a noticeable difference and would pretty much bolt in. The rest of the drive train is strong enough, but I think I would make sure on some things:
U-joints, differential wear, transmission, how many miles on them?
A higher than stock stall conver will effectively give you some more sli allowing higher RPM launches, if your not going to run aggressively on the street or race its not needed, but would allow some more fun factor. This would be a good oportunity to think about changing the tranny out with a 2004R, it has a better overall gear set and overdrive.
Your exhaust will need to be changed to true duals in order to let the new motor breathe
that get ya started?
I put a GM 350/330 HO Deluxe in my '80 6 years ago and love it. It dropped right in and bolted right onto the stock bell housing. (I have a 4-speed.) It's got more than enough power for spirited cruising with all the good manners of a street engine.
I put it in with the stock exhaust at first, but it really came alive when I switched to ceramic full length headers and true dual exhaust. WOW, what a difference! If your emissions laws allow, I recommend headers to get the most out of that engine.
The Vortec heads have centerbolt valve covers and most of the wire looms attach with the valve cover bolts. Look for adapters to mount the the wire loom directly to the block to clear off the top of the valve covers.
My only gripe is that the GM intake is ugly. I tried a high temp clear coat hoping to keep the bright aluminum look, but that yellowed. Maybe powder coating or ceramic would work. I think that was discussed in another thread not too long ago.
The stock air cleaner with snorkles didn't fit, so I have been using a 3" K&N open air filter on a drop base. That sucks hot air from the engine compartment which really effects how the engine runs on hot summer days. My winter project is to build a custom intake to pull air from ahead of the radiator. (Cowl induction isn't an option on an '80 without replacing the hood with a high-rise.)
The bottom line: Go for the GM 350 HO. You won't regret it if you want a cruiser with decent performance.
I went with the 290hp for several reasons:
1) I had just purchased a somewhat expensive set of chrome valve covers with the bolt pattern being on the outside...and the 330hp had center bolt pattern valve covers. And I wanted to use the new ones. I know I could have gotten an adaptor for the valve covers, but I like to keep things simple.
2) I also planned to use my 75 Vert as a cruiser/daily driver and not a racer. Oh sure, every once in a while I would pound the pavements....but that was VERY seldom...so the 40 additional HP was not an important factor.
3) Cost. At the time, the 290hp (from Summit Racing) was $1699. The 330hp was $2,599. The $600 difference for 40hp? I know the 330hp has a little more torque...but I couldn't see the difference. The other day I drove a friend of mine's '77 with 350/330hp down the street and back to see if I would notice any difference. Honestly, I noticed a little difference...especially at the higher rpms (3500-4000)...but not enough to say WOW (like driving a Z06) And NO I didn't "dog" his car..I drove it like I drive mine.
I am very pleased I installed the 290hp. Hope this helps in any way...Good Luck.
Oh, one more thing...the warranty on a GMPP is FANTASTIC! (24mon/50,000miles). Initially I had some problems with the valve guide seals...took it into a GM dealer, they verified my information and fixed the problem with no fuss/no muss. Got it back that same day.
Good luck with your project.
Kenny
Good Luck
A close friend with a '66 Vette installed a GMPP 350/290 and absolutely loves it. It's strictly a cruiser and he couldn't be more happy with it. The tired engine he took out of the was a 327/250 so the difference was quite noticeable to him.
Kenny
Both TurnKey & DELUXE 350HO comes with small 153T flexplate for automatic. Pretty sure OE 77C3 has larger 168T regardless if auto or 4spd. Dunno if yours auto or man? Your 77 flex/fw will NOT fit those motors. If you have an auto then it's cheap to buy a new flexplate ... but new flywheel a good bit more $.
If it were mine I'd definately prefer the crates with vortec heads over the old style heads on 290hp. I'd probably prefer Base 350 HO p/n 12486041 ... it does NOT have any of the following: flex/fw, intake manifold, distributor, water pump, harmonic damper. Use your distributor & damper & carb ... but buy an intake, waterpump, flex/fw.
-edit- ... I've got f/s for under $100 ... a good used plain lowrise satin intake for vortec heads that'll fit under a low vette hood & has both spreadbore& squarebore carb pad ... EMAIL (no pm!) thru this forum only if serious. This'll fit 77 w/ 350HO crate.
No reason to spend 6 grand on a weekend motor. also i saw where you can get the 290hp gm motor for like 1800.00, some bolt ons and its 330hp for lets them 3k
http://www.yearone.com/serverfiles/f...crate&SM=2&SC=
rich
