2004R Shifter Cable??
Old Dec 16, 2007 | 12:26 PM
SIXFOOTER's Avatar
SIXFOOTER
Default 2004R Shifter Cable??
How did you guys hook up the shifter cable? Does it go forward and loop back? I just went to install my original cable and the end of the cable is WAY forward of the linkage arm?
WTF?
Old Dec 16, 2007 | 12:50 PM
redwingvette's Avatar
redwingvette
Each trans has a different cable bracket to match the holes in the oil pan. I used the original cable when I did my conversion but the bracket had to be replaced to match the 200-4R. I got the bracket with the trans from BTO. It had several holes/slots in it so I think it was made to fit either the 200 or the 700. I place the shifter in park possition and then attached the cable tothe trans shift bracket. Then I attached the cable bracket to the trans by the oil pan bolts.
The cable does go toward the front as it comes off the shifter and it loops back and then loops forward again to attach to the trans.
Old Dec 16, 2007 | 01:11 PM
SIXFOOTER's Avatar
SIXFOOTER
Thanks Brian, guess that will work ou becaus I can't find my old bracket either, buried in a box somewhere
Old Dec 16, 2007 | 03:29 PM
redwingvette
Be aware that there is a bracket for the steering lock cable that you will need too. I made my own. I do not know if anybody makes one to fit the bolt pattern of the OD trans.
Old Dec 16, 2007 | 03:40 PM
SIXFOOTER's Avatar
SIXFOOTER
Hmm, Mine didn't even have the lock cable on it to start with
Old Dec 17, 2007 | 01:09 PM
markdtn's Avatar
markdtn
You can probably use the bracket from something like an 86 Grand National or Cutlass with floor shift and 200R4
To 2004R Shifter Cable??
