March Serpentine Setup Questions
Old Dec 18, 2007 | 11:37 AM
houstonvett's Avatar
houstonvett
St. Jude Donor '09, '24
Default March Serpentine Setup Questions
I was looking at the March inboard setup for a small block. Has any Forum member installed one in a C3 as of yet and any problems in the installation? The Sanden A/C and alternator that come in the kit are clocked different then stock pieces to fit March's brackets. Also does the front crank pulley have clearance issues like some of the GM units from Camaros and TAs. TIA for the help, houstonvett
Old Dec 18, 2007 | 11:53 AM
panic's Avatar
panic
I have the march set up with no a/c pulley though, no clearance iussues with the crank pulley whatsoever in my application.
I've bought my 406 SB already with the set up bolted on so i dont know what would be, if any, the iussues to fix it but i dont think it would be that complicated.
Old Dec 18, 2007 | 01:27 PM
Brandywine's Avatar
Brandywine
I have the March serpentine setup on my ZZ4 with a/c. The only problem I experienced was with the a/c compressor pulley cover. Just a bit close to the upper a-arm.
To March Serpentine Setup Questions
