Blinker problems
Old Dec 18, 2007 | 07:16 PM
Dante7's Avatar
Dante7
Default Blinker problems
Hey guys my right turnsignal will not work with my lights on and it has me totally puzzled. It works with the lights off, and the right works just like it should. What should I look at?
Old Dec 19, 2007 | 12:30 PM
kansas123's Avatar
kansas123
I have learned my lesson on light problems: run the grounds down and make sure they are good. I am no good at electrical and those diagrams in the repair manuals are hard to follow, but that is what I beleive you have to do. I assume you have looked at the lights and fuses and all that stuff to see that they are correct. Good luck, I hate Electrical....................
Old Dec 19, 2007 | 02:23 PM
Ragtop_Rob's Avatar
Ragtop_Rob
St. Jude Donor '17
I have to agree here, things like this are almost always faulty grounds.
Old Dec 19, 2007 | 02:41 PM
Glass Act's Avatar
Glass Act
From: 406ci SB, AFR 180 Heads - 490 HP @5,600 RPM 529 lb-ft @ 4,100 RPM
Check your bulbs also, when your park lights are on, is the right side brighter or dimmer front or back on that side. Not sure what year car, but some, the parking lights on the front are on when the headlights are. Pull the right front bulb and see what happens.
Old Dec 19, 2007 | 03:10 PM
wombvette's Avatar
wombvette
Its the ground on that side, plain and simple.
Old Dec 19, 2007 | 03:45 PM
427-390's Avatar
427-390
Or blinker fluid.....
Old Dec 19, 2007 | 08:55 PM
wombvette's Avatar
wombvette
Oh Yea, The blinker fluid is low. Thats got a be it.
Old Dec 19, 2007 | 09:22 PM
Dante7's Avatar
Dante7
I will take a look at the grounds tomorrow... Too late guys I checked the blinker fluid when I topped off the headlight fluid the other day so thats not it...
Old Dec 20, 2007 | 10:25 AM
427-390's Avatar
427-390
Like the others have noted, start with your ground connections. Even though they may look solid and secure, I would remove them, check the connector, clean off both the connector end and the mounting side, then reattach. Good luck! Oh, BTW, I'm glad you topped off all your headlight, blinker fluids.
Old Dec 20, 2007 | 12:37 PM
G dad's Avatar
G dad
From: THE OLDER I GET THE BETTER I WAS! NORTHERN ONTARIO
Yup!
To Blinker problems
