Compression Ratio Calculation
Old Nov 26, 2001 | 01:12 AM
Blake-73's Avatar
Blake-73
Default Compression Ratio Calculation
I am trying to figure my exact CR. I have a 383 (400 crank with 3.75 stroke and 4.03 bore) with 64 cc heads, flat top claimer pistions with 6 inch rods,
stock head gasket. I am guessing around 12-1. I am looking for something more exact if someone can help me out.
Blake-73
Old Nov 26, 2001 | 01:18 AM
ddn's Avatar
ddn
Default Re: Compression Ratio Calculation (Blake-73)
http://www.angelfire.com/fl/procrastination/motor.html
http://www.ondoperformance.com/
Old Nov 26, 2001 | 03:55 AM
BAD-L88's Avatar
BAD-L88
Take your pick:
http://www.smokemup.com/utilities/ca...sion_ratio.cfm
http://www.musclecars.net/KnowledgeB...mpression.html
http://www.bgsoflex.com/cr.html
Old Nov 26, 2001 | 09:28 AM
Matt Gruber's Avatar
Matt Gruber
would need to know thickness of head gasket, cc of valve reliefs
Old Nov 26, 2001 | 09:45 AM
Matt Gruber
it is close to 10:1, but can't be exact, without a teardown. Even then, you would have to check with bill clinton to see what the definition of "exact" is :lol:
To Compression Ratio Calculation
