Trying to learn about timing/tuning.
I have a 1970 L46 Vert with a small block 350/350. The block casting numbers and stamp pad are correct to what the car is supposed to be so I assume the bottom end of the motor is original as I haven't had it apart. Someone put on aftermarket AFR 195 aluminum heads, which are ported and polished, as well as roller lifters and rockers. A previous owner also replaced the points with a Mallory breakerless optical signal. These are all good things and help the car run better.
But in the distributor, the centrifugal weights and springs look very old and don't move well. They were sticky from old grease or something. Also, the vacuum advance was disconnected, which is probably why I get worse gas mileage than other people report. I only get about 10 in town and 12 on the freeway with 3.08 gears. I'm guessing someone did that to tune it to pass emissions.
My goal is the verify the timing and then go about setting and tuning the carb, which is an aftermarket Edelbrock/Carter AFB 600 cfm with electric choke. The carb sits on a nice little mid rise Edelbrock dual plane intake. The car starts easily (now that I have a new battery) and has lots of low end torque. Its a great setup for the street since I don't go to 6000 rpm often (or ever).
But, when I try to check the timing, the TDC #1 mark on the harmonic balancer is nowhere in sight. I can see that there is a very steady spark signal as I can see the harmonic balancer does not bounce around at steady rpm. I also see I have spark advance as the balancer does advance with revs when the vacuum advance is hooked up. I haven't checked the cetrifugal advance with the vacuum disconnected.
I suppose I will go and buy a dial back type timing light so I can see how far the mark is off. I can't imagine the timing is that far off and more likely the balancer has spun. I read that the 350 is internally balanced so what does the harmonic balancer really do?
How do I absolutely verify the #1 piston is TDC? I really don't want to pull the head or timing chain cover if I don't have to. I would rather just put a mark on the balancer or something...
Also, is it hard to pull and replace the stock balancer?
Thanks in advance! Merry Christmas
you can make your own mark there but i'd replace the balancer if its off since it will most likely slip again. to change it's easy. pull off your belts and crank pulley. you may have to pull your fan and shroud depending on how much room you have. then get a puller and use a balancer installer to put the new one on.
you dont really need a dial back light. you can buy timing tape or useing simple math find the measurements that equal what ever degrees you want and then mark the balancer yourself
old school works for me too
Is it possible the distributor is installed on the wrong tooth and still run correctly?
First...Do you the pickup for the timing light on the #1 wire? I bet every one here has make that mistake at one time or another.
You WILL have to rebuild the distributor, not hard to do ...or you can send it to lars!
Hell send him your carb too!
You get your stuff back and after reading Lars paper on timing, AGAIN, fire it up and no more problems!
Simple!!!
One thing that happens a lot is that the balancer's paint wears off which makes it hard to see. Make sure there's a nice white mark to look at. A paint pen or whiteout pen really does the trick here. I hightly doubt your timing is so far advanced you can't see the mark, either you're on the wrong wire (number 1 wire is on the driver's side all the way forward), your balancer has spun, or the marks are just hard to see.
I'm still learning about timing as well (I'm having detonation from setting my curves too soon), but you need all three set correctly. Vacuum advance is there for a reason and only racers have I ever seen run without it. If the dist is really bad, you'll have to get it rebuilt. If the springs are just rusty, you can order new ones from mallory (which will also let you select your own curves if you want).
Good luck!
I have the stock distributor, not a Mallory one. I only have the Mallory Unilite points replacement inside the stock distributor. One other thing that cduemig might have cleared up is that the #1 tower on the distributor cap is one post counter-clockwise than what the shop manual says it should be. The vacuum advance is also a little twisted further clockwise than it should be and is up against the ignition shielding post. I am beginning to think that the distributor was removed and re-installed onto a different tooth.
Also, if the groove on the balancer is supposed to be the 0 mark, it may have spun.
If it's running good even under load, it can't be that far out so the mark must be off.
There were two different timing pointers used in that era and they must be matched to the harmonic balancer. If the pointer and balancer don't match, you can have everything else correct, i.e., distributor positioning and secondary wiring, and still not get the timing mark to line up for the #1 cyl.
The cable drive does look stressed... I need to fix this.
Thanks, I had the same exact thought and will tackle it this weekend.
Even if the engine is internally balanced, it needs a harmonic damper to damp out minute harmonic vibrations that would increase wear on the driveshaft. Most auto parts places will lend you a puller to remove and replace the balancer. It's fairly easy to do.
If the balancer is original, it might have rotated on the shaft and it's due to be replaced.
