hey guys, i just traded my c4 for a c3. each time i hit the brake it pulls hard to the right. any suggestions on what to look for first. is there a good up grade that is worth the expense over the factory brakes.
thanks.
Oldcowboy
I would have to guess the right brake is the one working and the left is not.Check the left for leaking and the the left rubber brake hose for restriction.
Although it is more than likely a brake issue, do not ignore a possible suspension issue. I chased a hard pull to the left on my car for over a year and I discovered the problem when rebuilding the front suspension. The inner bearing race on the left side was spinning in the hub. I would eliminate the brakes as an issue first though.
good point BB. is always better to hear of other experiences before buying un needed parts. it could be the tires but they are almost new, hardly any wear and it drives fine until you hit the brake, then hold on lol. will keep ypu posted on what i find. thanks guys
