VB&P Front Mono Ride?
Old Dec 26, 2007 | 05:42 PM
doug_dayson's Avatar
doug_dayson
Default VB&P Front Mono Ride?
Regarding ride comfort with F41 levels of performance, how much does the ride improve with the front mono spring adjusted to something comparable to 460-500 lb/in (over traditional coils)?
My car has a custom ordered VB&P 345 lb/in fiberglass rear spring and Bilstein Sports all around, VB&P 460 lb/in coils cut 2/3 of a coil up front, 1 1/8" front bar and 5/8" rear, and Steeroids R&P steering.
I noticed quite a ride improvement over the old steel spring when adding the VB&P rear spring, so I'm wondering how much the front improves the ride similarly?
Thanks...
Old Dec 26, 2007 | 09:58 PM
MN80Vette's Avatar
MN80Vette
I have the VB&P front mono spring on my '80 with a VB&P 360# spring in the back. My car originally had the Gymkhana suspension. I have the front mono spring adjustment bolt in the second hole from the outside (equivalent to the 550# Gymkhana front coils).
Handling and especially the ride are noticeably better with composite mono springs front and back, probably due to lower weight. Cracks/seams and small bumps in the road are absorbed more than with the Gymkhana suspension I had.
You also need to switch to a good gas charged shock to handle the quicker movement of the composite springs front and back.
Old Dec 31, 2007 | 02:14 AM
doug_dayson
Thank you!
To VB&P Front Mono Ride?
