I Need A Mirror Location
Old Dec 26, 2007 | 07:04 PM
flstfi's Avatar
flstfi
Default I Need A Mirror Location
I just purchased some rally mirrors. The drivers side has the mirror controller somewhere in the drivers side door. I have two questions
1. Where in the interior drivers door do I put the mirror adjuster?
2. Since I will installing be a mirror on the passenger side (wasnt one there before). Not sure about proper locations for the mirrors?
Old Dec 26, 2007 | 08:09 PM
Gary's 1977 Vette's Avatar
Gary's 1977 Vette
Take your door panel off and on the lower front of it you should have a cut out from the inside that shows you where the remote lever goes. Cut it the rest of the way through and you have it.
Also when you have the door panel off you will see the 3 cutouts in the top steel part of the door where the adjuster goes through the BIG hole and one smaller holle on each side of the big hole where the mirror bolts go so you can tighten them up.
