No power to starter
Old Dec 26, 2007 | 07:56 PM
Enersis's Avatar
Enersis
Default No power to starter
id have no power to fuel pump unless i was in the crank position, once i let go and the start stops cranking i lose power.
replaced the ignition switch,and lock cylinder Now i have power to fuel pump, but the starter wont crank.
Old Dec 26, 2007 | 08:52 PM
Enersis's Avatar
Enersis
is there somthing in the steering column i could have messed up that would make it not crank?
Old Dec 26, 2007 | 09:36 PM
DZRick's Avatar
DZRick
Tell these guys what year your vette is and as much info as possible as to what you did under the dash.
There are some sharp guys here and I'm sure someone will be along soon to get you up and running.
Old Dec 26, 2007 | 10:24 PM
Enersis's Avatar
Enersis
ahh sorry im stupid.
It's a 78' havent done much under the dash other then new ignition lock, and switch
Old Dec 27, 2007 | 06:10 AM
Enersis's Avatar
Enersis
bump
Old Dec 27, 2007 | 11:50 AM
Enersis's Avatar
Enersis
never mind i trace it back to a bad parking switch
To No power to starter
