Distributor angle on Dart Iron Eagle standard deck block - question
Old Dec 27, 2007 | 09:48 AM
GrandSportC3's Avatar
GrandSportC3
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
Default Distributor angle on Dart Iron Eagle standard deck block - question
My 434 engine is built on a Dart Iron Eagle standard deck block with .391 raised cam. Now, according to my builder, as also some information that I read online, the distributor angle is leaning towards the center due to the raised cam which can cause a problem of of leaks between the distributor collar and distributor boss on the intake as the gasket can't overcome that gap. Now I read a suggestion of angle milling the distributor boss on the intake by .090. Is this a good suggestion? I'm planning on changing the intake and if angle milling the distributor boss on the intake can eliminate those leaks, I will have it done. I just wanted to check if those specs are correct. I ASSUME that angle milling it by .090 means to angle mill it so that the part of boss towards the center of the intake is .090 lower - correct?
