Front suspension Work(bearings,shocks, & spring)
Old Dec 27, 2007 | 01:01 PM
wallifishrmn's Avatar
wallifishrmn
Default Front suspension Work(bearings,shocks, & spring)
I can't seem to get the front bearings races out. I'm afraid to pound too hard on them in fear of damaging something. Does it make any different which one you remove first? I see the cutout area to punch them but how hard do you have to pound on them? What is the best device to force them out with? Next I plan on replacing the shocks and last the springs (I purchased a spring compresser from VBP). Any suggestions on does and don't. Thanks Paul
Old Dec 27, 2007 | 01:14 PM
wjsullivan's Avatar
wjsullivan
For the races I used a punch in the cutout area. Work both sides evenly. I'm not sure how much damage you can really do at the begining. Keep in mind if you scrape the sides in those cutouts to get it started you will cover the scrapes over with the new races.
For the springs I rented a compressor from Autozone. It was of the style that has two swinging hooks on one end, threaded through a long rod with a forked foot that slides on. I disgarded the foot and turned the whole thing upside down threading the rod downward through the upper shock mount. I then compressed the spring upwards against the upper shock mount and undid the lower control arm from the frame, swung it out of the way and slowly released the spring. I did the same to install but had to hammer a little to slide the spring back into the a-arm pocket as I released it.
Old Dec 27, 2007 | 01:17 PM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
You should use a brass drift to knock the races out. Brass is softer and it won't damage anything in the hub. You can pick one up at most parts houses. It doesn't matter which one you knock out first. You do have to smack them pretty good, and yes on the cut out area you mentioned, so you'll need a heavy hammer. You'll also need race driver to install the new races. Your parts store should also have a set of these. As far as the other items you want to replace, it sounds like you need a GM shop manual for your car to help you along with repairs. Check Ebay. You shouldn't be without one. Good luck!
Old Dec 27, 2007 | 02:09 PM
SIXFOOTER's Avatar
SIXFOOTER
You need the hub rsting on a pretty solid surface and you have to smak it pretty good, once it starts moving you'll get the feel.
Old Dec 27, 2007 | 02:33 PM
Jud Chapin's Avatar
Jud Chapin
It's a good idea to place the rotor on a couple of 2x4's to absorb the hit and so that you don't damage the inside rotor surface when removing the inner race or the wheel stud threads when doing the opposite side.
Old Dec 27, 2007 | 05:46 PM
cottoneg's Avatar
cottoneg
I just did it. You already have some good advice.
As mentioned, I would put a board or 2X4 underneath the hub to protect it.
I started with a small hammer and will recommend of those bigger hammers that look like mini sledge hammers. It worked much better. They will come out with time and patience. Just start tapping one of the cutouts you mentioned. A few taps and move on to the next one. One thing that always amazed me is how hard the metal is. You hammer the heck out of it and it looks perfect.
To a point, you can use the old race to install the new one.
BTW after all this work, don’t cut cost. Buy a good quality bearing like Timken. I am sure others can bring up other good brands. If you want proof of quality, take a Timken in you hand and a cheapo bearing. The Timken will weight twice as much.
Old Dec 27, 2007 | 11:10 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Brass drift. Available cheap at Harbor Freight.
Old Dec 27, 2007 | 11:13 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Called a "drill hammer." Was used for drilling through stone in the old days for setting explosive charges.
Old Dec 28, 2007 | 04:42 AM
cottoneg's Avatar
cottoneg
I feel for wallifishrmn. He probably feels he could use some explosives to get the races out.
I'll have to remember that "Drill" Hammer. Also good when using a fork to remove tie rods and ball joints
To Front suspension Work(bearings,shocks, & spring)
