im getting a new front window for my 78 vette, justing wondering when the old one comes off, I will have treat a small of rust etc, is it ok to paint window frame with por15, or does the new window bonding glue stuff need to stick to bare metal??
dave
Wire wheel everything till it's bare. Apply Por-15, let it cure, depending on type of window sealer used, apply a top coat of a sealer primer, and then the new window can go in for many years of rust free trouble.
Edit: Added mention of sealant primer in case Butyl is not used. (Hadn't thought that a non-butyl sealer would be used.)
From: Wilmington DE, Drive it like you stole it, 68 327 4 speed coupe
Originally Posted by Durango_boy
Wire wheel everything till it's bare. Apply Por-15, let it cure, and then the new window can go in for many years of rust free trouble.
Hand on a sec, cleaning the frame, and filling anny holes is a good start.....
Howver I would not use por 15 without a primer over it here uless you were sure to use the old style Buytl (sp) window sealer.
The newer style epoxy sealers require a specific type of primer to bond to, anything else and youll lose the windshield for sure, I'll have to look up the name of the stuff i used and post later, but any good winshield repair shop can tell you.
Edited: because SIXFOOTER made an excellent point
cheers
tim
Clarify? Are you saying add a coat of something over the Por-15?
thats exactly what he is saying D, the por 15 when cured creates a surface that the window sealers can not bond to, ( though I think buytl could stick to anything). Unlike other muscle cars that use a rubber seal to hold the windshield in place, the corvette windshield is bonded to the frame, if this bond is weak due to the surface not being prepped right, the windshield will leak at best, and come free at worst. Also you must be sure that the edge of the windshield where the sealer will go has been cleaned and preped as well .
for the windshield frame, after cleaning, I used this stuff as a primer to ensure a proper bond between the windshield and the frame using a eurothane sealer
you need to top coat the POR15, then put the glass back in
CRL POWR 300 Series Urethane Pinchweld Primer
cheers
tim
Very good advice. The Por-15 does need to the top coated or primer coated to the seal to stick properly. With this advice in prep that window frame will never have a problem again and the window will have a good to seal.
I top coated the POR15 also. Most glass installers use a primerless urethane to set the windshield. Just be aware if you use the urethane. have nice tall bead. If you don't the glass will be lower than widshield revel moulding. The replacement glass is Thinner than the original. So "you or the installer" needs to pay attention when setting the glass.
Originally Posted by agent kronus
quick question, how do you take of silver trim off at the top part of the front window, with bending it?
dave
there is a trim removal tool you use. you slide it under the trim move it to left or right till you cath the tad, and then sort of pull lift twist till that tab pops free. after the tfirst few you get the hang of it
tim
will it come of without having to remove the silver t bar part on the t bar roof thing?
yes it will, the pillar post mouldings have to come off, and you can just open the wiper door, atleast i didnt take mine off, though i did tape the blades to the door to get them out of the way
