Prep for Spal Fans?
Thanks in advance!
If you haven't ordered yet, our sale is going on until next weekend. DeWitt's products are apart of that sale.
and NO, i'm not getting into any of those/that discussion again with anyone....
it's where I put mine, and it's fine....my DVM says so....
"PVM" controllers ??
your "DVM" says ?? Doctor of Vertinary Medicine?
In any case it sounds like I don't need to add wiring thru the cockpit, I just need to grab voltage supply from a supply that is key actuated and can handle high (30) amps.
DVM - Digital Volt Meter. Everyone should have one.
Rick B.
pWm, sorry,I mistyped.... Pulse Width Modulation....turns on and off the power to the fans, making a variable speed controller by essentially altering the ON time with the OFF time very rapidly they tend to be unreliable....and wiring them or any heavy constant load to the battery posts/starter cable is bad practice, as it upsets the charge the battery gets off the alternator when car is running, especially in traffic when loads are greatest on a hot day with a/c running....
Digital Volt Meter, more accurate for auto work than the old panel meter types.....been using one for decades now....highly recommended...sold at Lowes Depot....MY preferance is a Fluke meter....Fluke is the manufacturer for many other private label brands....
edit...your last comment there.....pull the power off chassis ground, same as engine really assuming you don't have other heavy wiring problems...under the pass engine mount to the frame,....
and the alt stud....the controll wire for the relay COIL goes to a switched hot, and the temp sensor keys the relay closing the main power 30 amp contacts.....
MY car is computer DPFI, so the computer tells the fans when to on/off....
AHHH yes, upside down getting dizzy while you wish you could be dizzy from beer.....trying to read the meter while wraping yourself around the steering column.....welcome to auto electricals....
