I am new to this forum and have a question about the front suspension for a 79. I have owned 7 Corvettes and always done minor work, but never a frame off restoration, as was done on this car.
Here is my dilema, the front end has all new poly bushings and stock springs and other suspension parts. I had a 4 wheel alignment done and the car drives straight, however when you look at the car from the front, it sits high and the front tires slightly tow in. If you take a tape measure, and take it from the top of the tire and to the lip of the fender at the highest point, their is a 4" difference. Not the look that I was looking for! Is it sitting so high because the car hasn't been driven alot? Back of the car sits right. Is this a spring issue?
Can I take the original springs and have them cut down, or would it be better to ditch the original springs and get aftermarket pair ( also brand recommended)? If aftermarket is the way I need to go, how do you figure out the size? Ultimately I would like it lowered about 3".
I did the frame off and put a ZZ3 350 crate engine in it. This shoundn't effect the weight distribution, as this is probably a little less in weight than the 195 HP beast that was in it originally LOL
If cash is not an issue you could go for a nice adjustable coil-over setup, if you're on a budget then different springs would probably be in order. bump for more opinions.
Thanks for the advice..budget blown a long time ago. 12yrs of working on this car on and off(not much work in the last six years), 1 divorce. 2 kids and lot of money later, I was fortunate to still keep some of my toys, Vette, boat etc. Lost the house that I designed and built, but replaced with a better one ( this took a while). Oh, and I don't have anyone nagging at me about how much longer will I be in the garage..LOL
sounds like you are bouncing back nicely. I'm new here too but this is a great community for support. I don't know much about cutting the springs, I'm sure someone here will have the best answer. Good luck.
Are you certain that the springs are seated correctly in the upper pocket? If they are, you can either cut the springs or change to 550# big block springs to lower the height. The 550's will stiffen the ride but they are supposed to lower the height ~1" from stock. I don't think the engine change would affect the ride height THAT much so I would suspect the spring installation first. The top end of the spring should cover ~1/2 of the hole in the upper spring pocket and the lower end of the spring just sits wherever in the lower pocket. I found that I had to use a crowbar to nudge the spring over to get it up into the upper spring pocket when I was installing my new springs. I stuck a screwdriver into the hole so that the spring wouldn't turn too much as it was raised.
That's good info, I didn't realize the big-block springs would lower the ride. If it turns out the springs are seated properly I have a pair of red powdercoated big block springs I'm not going to use since I'm going with the VanSteel coil over setup.
Rick..thanks for the advice. I will double check my work in the morning. I am sitting about 4" high in the front. I would like to stick to my stock springs, instead of going with 550's for right now. Can springs be cut without full disassembly?
I have a stock 79 sitting right here and I measure
3" with the stock springs. It has 225/70-15 tires on it.
The rear measures 3" also at the highest. Doesn't seem too bad to me.
From: Guantanamo Bay, Cuba (home in Colorado Springs)
OK, I don't reccommend this, but I have seen a guy actually heat up a coil spring with a torch to collapse it just enough to lower his car.
BUT! I would suggest using the BB coils. Vansteel or VBP could set you up nicely I bet.
As for the rear, you can go with longer bolts in the leaf spring (effective & cheap). Realign when done.
Unfortunately no. In addition, cutting springs seems to be a trial-and-error process. People seem to cut different numbers of coils to get the same end ride height. There are many posts in the archives regarding spring cutting but I think most people start with a full coil and go from there.
The 550# springs are probably 3" or so shorter than the stock springs when fully extended, but the 550's are much heavier guage and the coils are closer together. When we installed the 550's on the 72 we only had to compress the spring ~1/2" to 3/4" to get the nut started on the upper ball joint.
I am not familiar with poly a-arm bushings, but with the stock rubber ones you can get high ride height if you tighten up the bushing attaching bolts without the car being on the ground (i.e., up on jack stands). But, as I said, I am not sure if poly bushing pivot easily when the bolts are tight.
If you're going to cut your stock springs, only cut a half a coil at a time off. Its a tedious process, taking multiple installs to get the look you want.
The Vansteel coils are 1 1/2" shorter than stock.
If money is an issue, this is the way to go, half coil at a time.
The F-41 suspension (the 550 Inch/Pound spring everone is refering to) can be found at a reasonable prices and will lower the car 1 inch from stock.
DO NOT heat up the springs to lower the ride height. This will change the physical properties of the spring material and can result in a great many issues. Cut 1/2 a coil at a time and reassemble until you get the ride height you want. Make sure you keep the springs cool when you cut them too.
Try searching the Forum, there was a thread about cutting springs for ride height with in the last week or so.
Thanks for the advice. Seems unanimous not to cut the springs with heat. I will try the half coil trail and error cut next weekend. I really like the profile of your car..nice job! How can I view a larger picture than your avatar?
