C3 rear spring quality question
Old Dec 31, 2007 | 11:57 AM
midlifeclassic's Avatar
midlifeclassic
Default C3 rear spring quality question
I have removed the rear spring of my '78 L-82 and want to replace it.
One dealer gave me a price of $240 for threir spring, he said it was higher than most because it was U.S. made, others sell their's for around $130 but are foreign made and poor quality, acording to him.
Has anyone bought a rear spring from Corvette Central and had any quality issues.
Also, my spring is 2 1/4", 7 leaf, I beleive is the orginal. I've seen some conflicting info about 77-78 having 2 1/4 or 2 1/2" springs. Is my 2 1/4, 7 leaf correct.
Old Dec 31, 2007 | 12:20 PM
rihwoods's Avatar
rihwoods
For stock replacement I suggest Eaton...just give them a call
http://www.eatonsprings.com/ordering.htm
Old Dec 31, 2007 | 02:56 PM
VIPERBARON's Avatar
VIPERBARON
From: Guantanamo Bay, Cuba (home in Colorado Springs)
I took mine out & replaced with a fiberglass spring.
The original is now used to hold down the tarp on the tractor. You want it?
Old Dec 31, 2007 | 04:05 PM
L82shark's Avatar
L82shark
St. Jude Donor '08
Lots of places to get them from, VB&P, Van Steel, etc. just shop around. They also have rebuild kits for your original. Make sure you get new bolts and a mounting plate, it will make things easier. Also, if you do go to a glass spring, you will have to have some high quality shocks to go with it. Get some catalogs from them and shop it or visit the websites and decide which way you wanna go and will fit the budget.
Old Jan 1, 2008 | 11:01 AM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
If it isn't a "correct" show car, I'd consider the fiberglas rear spring from VB&P. Better ride, much lighter.
Old Jan 1, 2008 | 12:14 PM
427Hotrod's Avatar
427Hotrod
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
I'm using Vette Brakes on mine..with no issues. They even had their local builder customize it for my application.
JIM
Old Jan 1, 2008 | 01:27 PM
Smly1971's Avatar
Smly1971
I got mine at Bair's, it was very similar to the original. I took it apart after I got it and put the correct liners in, and painted the leafs.
Old Jan 1, 2008 | 09:20 PM
Yellow6t7's Avatar
Yellow6t7
midlifeclassic check you PM
Old Jan 1, 2008 | 11:45 PM
Glassbowtie77's Avatar
Glassbowtie77
Old Jan 2, 2008 | 08:23 AM
dmaaero's Avatar
dmaaero
63-77 has a 2-1/2" spring, the 78-79 has the 2-1/4 spring.
Old Jan 2, 2008 | 10:25 AM
sly vette's Avatar
sly vette
I have a composite single leaf in the rear and with the Bilstien sports it rides great...Now I need the bilsteins for the front. Anyone got any??
Old Jan 2, 2008 | 11:47 AM
75 Hot One's Avatar
75 Hot One
I agree. Eaton in Detroit is top quality for OEM replacement. They have original dwgs & specs. They may be a bit more expensive than some but you can depend on their quality. The big difference in leaf springs is that the top quality ones are low alloy (CrMo) whereas the cheaper ones are just carbon steel. If you're looking at a lower price spring, ask about the chemistry. The quality difference is that the low alloy springs are stronger and will retain their shape and spring properties longer.
To C3 rear spring quality question
