Okay, in regards to the front turn signal wiring plugs, looking at it from the front, which terminal is which color, and what is it's function.
My harness wire colors are all faded and it's very hard to get up in there for a good look. I don't have the stock male plug insert so all I have to go on are the colors from the C2 front signal male inserts.
OK, if this was your left socket, the top spade is ground, black wire, left spade, parking light, brown wire, and right spade, is turn signal light blue.
The right socket will have a dark blue wire for signal.
Thanks so much Binnie, and just to be sure since I seem to have confused myself, which intensities are the parking and signal functions of the 1157 bulb?
I seem to remember that the parking light is the low intensity and the signal is the high intensity.
