Trailing arm bolt removal
Old Jan 5, 2008 | 07:53 AM
Simmo's Avatar
Simmo
Default Trailing arm bolt removal
Ive searched this subject and found I have to cut the bolts out with a rotary saw (just bought one with bosch 8" 18pi blades, I couldnt get a carbide blade.).
Do I remove the shims first? If so how (1970), the shims can rotate, do they have slotted holes for the bolt, do they have to be bashed in later at reinstal or does the bolt pass through them. I cant see anything retaining them if they are slotted.
Do I try and cut through the small bit of exposed rubber bush if the shims dont come out before cutting.
Is it easiest to remobe the caliper to get extra room for the saw.
Old Jan 5, 2008 | 08:13 AM
jnb5101's Avatar
jnb5101
i assume that you mean reciprocating saw, not rotary.
remove the shims, and just cut the bolt where the shims were. if the blt rotates, put a wrench on the nut or head. get good saw blades, milwakee or blue mol, and you'll cut thru the bolts in about 30 seconds. the shims have slots that the bolt passes thru, and there should be a giant cotter pin at the end that passes thru the trailing arm to hold them in. remove the cotter pin, pry the end up, put a crow bar next to the bolt and pry the sides apart just enough to free the shims.
jeff
Old Jan 5, 2008 | 09:00 AM
Vette-4-Life's Avatar
Vette-4-Life
Take pictures before you start since you will want to re-install the shims same way they came out. I went with the stainless shims since in all likelihood you will destroy a shim or 2 trying to remove them. Once removed cutting off the bolt will take only minutes.
When i did mine the caliper was removed.
When you re-install the hardest part will be replacing that pesky bolt, make sure you have extra long needle pliers and lots of patience.
Old Jan 5, 2008 | 09:02 AM
Gordonm's Avatar
Gordonm
You do not want carbide tipped recip blades. You will destroy the carbide with all the vibration and bouncing around. A carbide grit will work but will take forever. Get yourself some good bimetal blades, preferebly Lenox since I have worked for Lenox for 23 years but any good bimetal blade will do. A 14 or 18 tpi will do the job. A little cutting oil will not hurt either.
Old Jan 5, 2008 | 09:04 AM
88'Cubka's Avatar
88'Cubka
St. Jude Donor '08
I like the Lenox blades myself! Never failed me yet.
Old Jan 5, 2008 | 09:13 AM
JimT's Avatar
JimT
I just replaced the TA bushings on my '72. I sprayed penetrating oil on the bolts/bushings/nuts and let it soak overnight. I removed the nuts and then used a long pry bar and tapped on the bolt heads. Bolts came out and I dropped the arms. I then used a saw to cut out the bushings and sleeves. Get a long pair of needle-nose pliers, grease the new bolts, and they should go in easily. Be sure the bolts will slide in the bushings while the TA in out of the car. It takes time and patience. Also, when pressing in the new bushings, be sure to use the beveled washers on the sleeves as they eliminate any obstruction while installing the shims.
Jim
Old Jan 5, 2008 | 09:13 PM
Simmo's Avatar
Simmo
jeff
Well I finally got one side off.
The shims wouldnt come out because the bolt passed through a hole not a slot. And there is no hole in the trailing arm for a cotter pin. There must be differences between the years, mine is a 1970. Thin shims had rusted through in to bits.
After lots of penetrating oil I was able to drive the bolt out, lets hope the other side will do the same.
As there is no hole in the trailing arm to hold the cotter pin and new shims will be slotted, how will I retain them?
Old Jan 5, 2008 | 09:56 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
I thought the hole-style shims had been phased out by 1970. Does the frame have a small hole on each side of the pocket for a long cotter pin?
Old Jan 5, 2008 | 11:53 PM
Jeffery73's Avatar
Jeffery73
St. Jude Donor '08-'09-'10-'11-'12-'13
I used an air hammer to knock my bolts out. It worked like a charm.
Old Jan 6, 2008 | 01:48 AM
77TSi-meez's Avatar
77TSi-meez
Old Jan 6, 2008 | 08:10 PM
jnb5101's Avatar
jnb5101
simmo
the reason the newer shims have slots is to make it easier to add/remove shims to get proper alignment. if ther isn't a hole for the cotter pin, you can drill a hole thru the kick up of the frame. jack up the rear of the car, and support with jack stands. remove wheels, and use a jack under the spring bolt to raise the trailing arm a couple inches ( this makes it easy to drill the holes needed for the cotter pin). install the shims and push the end down into the "pocket" as far as posible. determine wher the retaining holes on the shims are located and use a right angle drill with a normal length bit to drill the outboard side of the kick up right thru the shim hole. then change to a 6" length bit to drill thru the inboard side. watch the brake lines that are near the inside surface of the kick up. this can all be done without a lot of trouble. had to do this on my 70.
jeff
Old Jan 7, 2008 | 06:58 AM
Simmo's Avatar
Simmo
Thanks for all the help.
The second bolt is not being helpful, so Im expecting to have to soak it for a week.
Close inspection of the first bolt showed it had stuck from corosion where the shims contacted the bolt and the bolt surface was ok at the bush face, The nickle cad plate was still good where it contacted the bush.
Yes an air hammer might be the go but the wife is spewing on me getting the saw. Good thing she doesnt know about the 533 and TKO600 I have bought to go in!
Old Jan 7, 2008 | 08:08 AM
JimT's Avatar
JimT
On my '72 the shims have a hole at one end (for the small bolt that holds them in the frame) and a slot that allows the shim to slide over the TA bolt for adjustment. There is a small hole in the frame that the small bolt (1/4 inch) is inserted through and goes through all of the shims after alignment. Sounds like a previous mechanic/owner used the wrong shims, or, placed them in backwards.
Jim
Old Jan 7, 2008 | 08:48 AM
jdmick's Avatar
jdmick
Sounds like you've discovered the most difficult aspect of the old Corvette hobby. No, not frozen T/A bolts but wives with no interest until the bill comes.
Old Jan 7, 2008 | 01:28 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Jim
1) C2s and early C3s used shims with a hole for the T/A bolt and no retainer hole.
2) There should be a long, thick cotter pin retaining the shims, not a bolt.
To Trailing arm bolt removal
