Pressure Brake Bleeding?
Old Jan 5, 2008 | 11:04 AM
76projectstingray's Avatar
76projectstingray
Default Pressure Brake Bleeding?
I have searched the forum and read almost every post and have not seen an answer to this. In my manual for a 76 it says if you pressure bleed the Brake system you need to make sure that the proportioning valve is held in the open position and they give tool # j-23709 to use? I have not read anyone saying that this was an issue? Please help!
Old Jan 5, 2008 | 11:27 AM
stock76's Avatar
stock76
I just bled my entire system with a Motive bleeder with no problems (silicone). Worked from back to front per my shop manual. Maybe that applies if you are filling and pressure bleeding a new system that has no existing fluid in the lines?
Hopefully someone else that knows for sure will jump in and answer this one.
Old Jan 5, 2008 | 11:28 AM
carriljc's Avatar
carriljc
Default Hasn't been an issue on my '68
I pressurize and maintain pressure between 10 psig to 20 psig.
Old Jan 5, 2008 | 04:31 PM
76projectstingray
It must not make a difference or someone would have mentioned it with all the other posts. I'm ordering the motive now. Thanks!
Old Jan 5, 2008 | 05:17 PM
'75's Avatar
'75
Since most brake pressure bleeders pressurize both front and rear parts of the mastercylinder the proportioning valve should stay centered especially since the bleeder pressure is so low it should not cause a problem. I made my own bleeder from a small weed sprayer from ace hardware and an old m/c cover. Had to solder up the vents in the cap and solder a hose nipple to it, but I made for about $15.
Old Jan 5, 2008 | 11:40 PM
Blue Seducer's Avatar
Blue Seducer
I just tried pressure bleeding my 82. rears bled, but had to pump pedel to bleed fronts. Also had to have engine running.
Old Jan 5, 2008 | 11:58 PM
dariopop's Avatar
dariopop
I also have a 1976 and just replaced all of my brake lines and I bled my entire system with a Motive bleeder with no problems .I have never heard of this tool # j-23709 , I have had my car for over 30 years and I have never read anything about one. Worked from back to front per my shop manual too. Came out great without a problem, LOVE THAT MOTIVE BLEEDER!!!!!! Worth every cent!!! Spend the extra money and get all three adapters and you can do any car on the market. I use it on all om cars from 1076 to 2007 Chev Motorhome. Someone also mentioned having to run the car while bleeding, that is normally required on new car with Anti-lock brakes while bleeding by using the brake pedal way. Not required to do on a new car with antilock-brakes if using the Motive brake bleeder. LOVE THAT MOTIVE BLEEDER!!!!!!
Old Jan 6, 2008 | 09:53 AM
76projectstingray
thanks , its on the way!
Old Jan 6, 2008 | 11:10 AM
Curby's Avatar
Curby
Cruise-In VII Veteran
St. Jude Donor '06
Where do you get the Motiv bleeder?
Old Jan 6, 2008 | 11:49 AM
Duke94's Avatar
Duke94
The special tool is used to hold open the Metering Valve in the front brake system. The Metering function is used to holdoff pressure to front disk brakes until you overcome the return springs in a rear drum brake. Since all C3 Vettes have 4 wheel disck brakes, there is no metering function so the special tool is not needed.
Old Jan 6, 2008 | 11:51 AM
Duke94's Avatar
Duke94
Summit Racing is one place.
http://store.summitracing.com/partde...5&autoview=sku
Old Jan 6, 2008 | 02:34 PM
wfo76's Avatar
wfo76
That doesn't seem right. Could have an internally collapsed rubber brake hose. Are they original?
Old Jan 6, 2008 | 06:29 PM
shoptek's Avatar
shoptek
I just finished building one also. Old weed sprayer, some vinyl tubing, a couple of barb fitting into an old MC cover. Total $$$ was $7 in parts (the weed sprayer was retired years ago, so ...no cost )
Old Jan 6, 2008 | 06:37 PM
pws69's Avatar
pws69
That's because you didn't use the tool!!
I have used these tools - in fact I still have one from the early '70s for "Ford" valves in my tool box. They screw in in place of the switch and hold the slide in the center position while pressure is applied for bleeding. Without the tool, the slide will go toward the side you are bleeding and close it off.
Old Jan 6, 2008 | 07:23 PM
76projectstingray
PWS69, so you agree that you should use this tool? nobody seems to use it?
Old Jan 6, 2008 | 07:53 PM
Duke94's Avatar
Duke94
See attached link. As I said in my other post, the tool mentioned is for cars with Metering valves. Vettes don't have metering valves.
http://www.autozone.com/az/cds/en_us...rInfoPages.htm
Old Jan 7, 2008 | 12:44 AM
Blue Seducer
Yes they are. I will install new hoses and try again.
To Pressure Brake Bleeding?
Old Jan 7, 2008 | 01:53 AM
Retro78's Avatar
Retro78
Actually I think the do... later 70 models. Called proportioning. The W type also contains the brake switch plus proportioning.
Old Jan 7, 2008 | 07:15 AM
pws69's Avatar
pws69
76projectstingray: If you have one, sure! Particularly if you use the pedal bleed method.
Duke94: not true - they were used with Proportioning valves and distribution valves (which the 69-70 do have).
If you do not use the "tool", and use the pedal bleed method, the slide can be pushed to the "open" side with sufficient pressure to cause it to "stick" in that direction. Pressure bleeders have much less pressure than that which is created by pushing the pedal so it usually isn't a problem.
Old Jan 7, 2008 | 09:58 AM
Patrick73's Avatar
Patrick73
http://www.hrpworld.com/index.cfm?fo...action=product
