Compression check...How am I doing?
Old Jan 5, 2008 | 02:58 PM
jim2527's Avatar
jim2527
Default Compression check...How am I doing?
Engine is a 350 with unknown internals and stock '70 steel heads.
To help understand my setup:
1. Rebuilt '76 Q-jet
2. Reshimmed stock distributor
3. MSD custom cut wires with Champion plugs.
4. Dwell is correct and timing is within reason
5. ~13mmHg vacuum at best
6. Idle is ~950-1000 I cant get to idle any lower and its still choppy
7. My right exhaust is more 'rumbly' than the left. It has stock manifolds on the wrong sides. The heat riser valve is on the left and stays mostyl closed.
8. I have no idea if the vlaves are properly adjusted.
Cylinders:
1. 140
2. 150
3. 140
4. 150
5. 140
6. 140
7. 135-ish
8. 150
Any thoughts or comments?
Old Jan 5, 2008 | 03:33 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
How does it run ? Looks like a motor with a few miles on it the cranking compression is a little low but within tolerances
As for the idle you should be able to fix that with timing and carb adjustments
Old Jan 5, 2008 | 04:15 PM
Clue's Avatar
Clue
My 1974 BB is in the same range as yours, it runs good and idle is a little rough but i think someone put a bigger than original cam in there. If you have a big cam I have learned that cranking compression will go down but I'm not sure on this.
Also my idle vacuum is in the low 10-12 range, yours at 13 and that's low too. A big cam will produce such numbers.
Am I wrong on this?
Old Jan 5, 2008 | 07:15 PM
jim2527's Avatar
jim2527
I'm thinking it may have a bigger cam but really have no idea.
As far as timimg I dont know what more I can do. I have 36 (initial plus mechanical) then the vacuum on top of it.
Old Jan 5, 2008 | 07:20 PM
Clue's Avatar
Clue
I think 36 initial is way too much, you should be at half of that I guess.
Old Jan 5, 2008 | 07:52 PM
chris75stingray's Avatar
chris75stingray
he says initial plus mechanical, so thats good
Old Jan 5, 2008 | 08:30 PM
Clue's Avatar
Clue
He sure do, my mistake
Old Jan 5, 2008 | 08:39 PM
PeteZO6's Avatar
PeteZO6
Just curious Jim, what do you mean "reshimmed stock dirtributor"?
Thanks,
Pete
Old Jan 5, 2008 | 08:50 PM
weimer20's Avatar
weimer20
Those numbers look ok to me.
Old Jan 5, 2008 | 10:27 PM
jim2527's Avatar
jim2527
Thanks,
Pete
There should be no more than .007" clearance between the cam gear and distributor housing. Any more than that will cause the rotor to move up and down as it rotates causing a mis-fire. I threw that in there to let it be know it wasnt the cause of my 'rumbly' idle.
Before reshimming I was at .035".
Old Jan 5, 2008 | 11:17 PM
BigBlockTank's Avatar
BigBlockTank
You said that the left side has the heat riser on it? And it stays mostly closed? That's the #1 problem to clear. The #2 situation to clear is the valve adsjustment. After those are cleared and you're happy about that, try running the engine with no vacuum advance, some engines like it, some don't. What are the spark plugs gapped at? Try .005 more or less and see how it idles. Do that a few times to see if it smooths out.
The vacuum issue could be a leak in either the intake somewhere, or with headlights or windshiled wiper door? Mine was about 9" vacuum at idle in gear at about 850 RPM's. Since all vacuum leaks are fixed, timing is good, carb adjusted, and I have 13-14" vacuum now. Methodicly is the answer to all problems.
Old Jan 6, 2008 | 09:56 AM
jim2527's Avatar
jim2527
I'm working on the riser issue....Its rigged open with a wire until I can get an eliminator for it.
Valves...They could be properly adjusted but I just dont know. I'll leave that for a different thread
Plugs are gapped at whatever the book says for a '70.
Vacuum system is tight. All new components and hoses. Wiper system has been isolated (tubing is clamped).
Old Jan 6, 2008 | 11:43 AM
dannyman's Avatar
dannyman
A compression test is good for a quick check, but a better test is a leak-down check. The leak-down test will isolate a problem better such as partially stuck intake/exhaust valve etc. The following link gives an excellent description of the procedure and expected results.
http://www.geocities.com/dsmgrrrl/FAQs/leakdown.htm
This check will give you a definite answer to how your engine is operating.
Old Jan 6, 2008 | 05:25 PM
BigBlockTank
Beat me to it.
Old Jan 6, 2008 | 06:38 PM
jim2527's Avatar
jim2527
I'd run a leak down test but dont have the proper equiptment (air compressor).
Are there any good links for easy at home valve adjusting?
Old Jan 6, 2008 | 07:24 PM
dannyman's Avatar
dannyman
You may be passing up a chance to buy tools for the garage!
You can build a leak down tester;
http://www.xs11.com/tips/misc/misc3.shtml
and then buy a cheap compressor (inflate flat tires or kids bike tires).
To Compression check...How am I doing?
